Ive got a problem with my 84.The left signal is dead.the bulb is fine and it will flash with the hazard lights.With the lights off I can work it manually by hand up-down at the column but when I turn on the lights the left indicator in the dash is lit,no parking light in the front but taillights in the rear but with the lights on it wont do anything.It cant be the flasher,they flash with the hazards.Im think headlight switch or TS switch.Thanks.
There are separate flashers for the turn signals and the hazard lamps. Do the turn signals work on the right side?? If they don't work there either, I would suspect a bad turn signal flasher.
If the right side works, it may be the turn signal switch on the steering column.
How about the rear left side bulbs? Do both rear bulbs flash with the hazard flasher or with the brake lamps? The flasher works from the load resistance in the circuit. Take a bulb away and the load decreases and the flasher doesn't get enough heat generated on the metal contacts and won't flash.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Check all your bulbs. A bad bulb can cause this. If i remember correctly, I had a bad license plate bulb causing the exact same thing. Hazards worked but no signal on that side.
Also the blinker i bought at pep boys SUCKS. It's noisy, you can hear it clicking inside the dash. If you do need a new blinker, buy from the dealer perhaps.
Ive had this car apart for the past 6 weeks replacing the windshield and now ive got to fix something else,this gets old.When checking the bulb I found a broken wire at the socket.The wire is off to the side and not grouped with the wires at the end of the socket,ill rig it to make contact and see if thats the problem,if not ill change the switch.Thanks for the info guys,Jeff.
Hey guys,found a broken wire at the socket.When I pulled the bulb to check it everything seemed fine at the socket,went back and to check and found the wire.Made contact and it works.Thanks for the help guys,Jeff.
