Help! New C4 owner needs transmission experts
Old Nov 28, 2005 | 04:32 PM
UniqueDoug's Avatar
UniqueDoug
Default Help! New C4 owner needs transmission experts
Well, I just bought a '94 Automatic with 108k, and I was driving it the other day around 40 mph and it started going from 4th to 3rd to 4th to 3rd; maybe around 6 up/downshifts in 30 seconds. It was in overdrive of course. I put it in D after that, all was ok. Then back to overdrive and it seemed like it went away. No idiot lights on dash. Tranny fluid ok (level good and clean). Shifts fine; strong acceleration. What is up? Thank you in advance!
Old Nov 28, 2005 | 04:37 PM
vader86's Avatar
vader86
Probably due to the fact that ~40mph is the magic number, EPA guidelines force the computer to want to shift to 4th at around those speeds. So in effect the transmission is 'hunting' between the 2 gears if you are close to that speed. Once you stay over that speed for an extended time it will stay in 4th, but if your speed is fluctuating the transmission will shift.
This is why I leave my own car in D unless I know i'm going to be over 45mph for a few minutes at least. The 3-4 clutch pack will wear out.
Old Nov 28, 2005 | 05:19 PM
MBDiagMan's Avatar
MBDiagMan
Although I am ASE certified on automatic transmissions, I don't consider myself an expert.
I will say, however, that the first thing I would do is make sure that there is a strong vacuum signal to the modulator. If there is not, check the modulator for leaks. If it is okay, check general engine vacuum. If it is low, find the leak and fix it.
Good luck,
Old Nov 28, 2005 | 05:26 PM
bogus's Avatar
bogus
it would never hurt to have the transmission serviced - a powerflush and a new filter.
I recommend Valvoline or Mobil 1 synthetic transmission fluid.
Old Nov 28, 2005 | 05:50 PM
brookman's Avatar
brookman
Just so you are aware the 94 has an electronic controlled transmission - there is no vacuum involved. 4l60e. Even the 4l60 which is the earlier no-electronic version did not use vacuum. It used a TV cable which controls line pressure in the transmission.
Old Nov 28, 2005 | 06:08 PM
MBDiagMan's Avatar
MBDiagMan
I learn something new everyday. I was not aware that the electronic transmissions went back this far.
Have a great day,
Old Nov 28, 2005 | 09:09 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
So is it kinda like a rare event for your car to go over 45 mph? jk.
Old Nov 29, 2005 | 05:19 AM
conv90's Avatar
conv90
Old Nov 29, 2005 | 10:48 AM
UniqueDoug's Avatar
UniqueDoug
Thanks for all the info! I am really enjoying my C4 experience so far. I am 6'5", so it is a little tight. But, it's tolerable since it is not a daily driver ('03 Lightning). The C4 experience is a much more organic experience than when I had my C5's. The "roughness" and edge of the car I believe add to the experience of driving it!
Old Nov 29, 2005 | 03:40 PM
NJPetes89's Avatar
NJPetes89
I like the way you think! I got my Gen 1 Lightning a C4 playmate, They are both a blast to drive!
Old Nov 29, 2005 | 03:44 PM
UniqueDoug's Avatar
UniqueDoug
What year were the first generations?
Old Nov 29, 2005 | 04:39 PM
NJPetes89's Avatar
NJPetes89
Gen 1- 93 to 95 They were not supercharged from the factory They just barely out preformed the Chevy SS 454. Gen 2- 99 to 2004. Don't know for sure if thier will be a Gen 3???
Old Nov 29, 2005 | 04:46 PM
UniqueDoug's Avatar
UniqueDoug
Latest word from SVT is NO gen 3...The concept Ford has shown is the four door Adrenaline, with like 390 hp (come on, gotta have at least 500!). Whoops, we better watch out, this may go to off topic!! :o
To Help! New C4 owner needs transmission experts
