Slow to stop at high speed
Stainless brakes lines are a gimmick really. I would only use them if your stock lines are rotting.
I haven't seen any failures on here, for either SS or rubber. Also keep in mind that forum members with ss lines probably only have a few years on them.
I have ss hoses up front, didn't have any choice really. I applied shrink wrap to them to keep the grit out.
Wilwood has some coefficient vs temperature graphs for different compounds, I've never seen this for Hawk though.
A flush and some better pads will do wonders. I changed over to the Valvoline synthetic when I replaced my MC, and EBC Greenstuff pads. Brake fade improved dramitically. My stopping distance didn't change, nor did pedal effort, but I could pull the car down from 100+ and not have to worry about being able to stop and running off the end of the track into the bushes. The pads were a bit pricey but worth every penny, and don't require any warming up for acceptable street performance IMHO.
Checking out the vettes brakes is a good idea, but I was just thinking that its possible you were stopping from a much higher speed that you probably would likely be traveling in another vehicle. It was just something I thought of. I know in my car, I'll be playfull and mat the gas on the highway, and it almost seems like everyone around me just magically dissappears and next I look down and I'm in tripple digits. I'm not quite used to that, even after owning two LT1 f-bodies! It was just a thought.
You could also see if you have the J55 brakes or not. That is a possible upgrade.
I have not used the Hawk HPS pads, but as I understand it, the HP-Plus is more aggressive than the HPS. I have use the HP-Plus and they stop you like a brick wall
, but dust like crazy.I have also used PFC pads, and I think I agree that they don't dust that much. They do stop great with heat, but you may notice that it takes more effort to stop cold. I don't like them much for in town driving.
Stainless hoses. I have also heard most of the same things. I have full, well I skipped the MC to prop valve, but otherwise complete stainless lines and hoses on my CJ7, and they did give a very solid pedal feel. It is quite unique and I like it, but I don't believe it actually helps you stop "faster" unless maybe you can work in the small time it takes to stretch the hoses to size when braking.
YMMV. »keith
Also flushing brake system is of minimal benefit. Brakes are a static pressure system in that the fuid is only a means of transmitting force to the caliper. There is no real "flow" through the system. But hey flush them if it helps you sleep at night.
Incorrect. Brake fluid will absorb water from the air and lower the boiling point of the fluid. If the boiling point of the fluid is low enough it will boil when you're trying to pull yourself down from triple digits, or riding the brakes going down a steep grade, and you won't have any brakes!
It's much easier and cheaper to first make sure the braking system is operating as it should then to immediately jump into an upgrade. You may find that for your own driving preference that the stock system is adequate.
I've witnessed the benefits of fresh fluid over old crusty junk, even in a street vehicle because who knows if the last owner ever changed the fluid.Now, I will say 95% of the time, its not going to affect street braking, but it is an easy 5% to cover and it will definitely help the components last longer.
»keith
Stainless steel lines will help firm up the pedal.
I have a set on a race car that are 15+ years old and have no problems from brake dust,road dust or age. In fact, I can't remember ever hearing about a line failure.
Flushing a brake system is of minimal benifit ?
Upstate is correct, brake fluid is hydroscopic, it absorbs water. This increases pedal effort. If I have previously opened can in my shop and it's over 3 months old, I throw it out. Brake fluid is cheap.
Also I bleed the calipers every race and totally change the fluid every 3 races. There is a noticeable color change in the fluid after one race.
Bill Hetzel
MLC Motorsports
The synthetic will have a higher boiling point. Given the cost difference I would just go with the synthetic. The boiling point is higher and you'll have some security should you decide to do some spirited driving. They're aren't any precautions I've heard of about mixing synthetic with regular fluid. But you're going to be flushing the whole system anyway so it shouldn't much matter as you're going to be running brake fluid out of the calipers until it's nice and clear. I run the valvoline synthetic and drive pretty hard and haven't had any problems.
One tip, make sure the resovoir doesn't empty while you're flushing or you'll have even more fun getting the air out of the MC. I'd be sure to follow the factory procedure for bleeding as well. You should bleed in a specific order but I don't know it off the top of my head. Somebody else will chime in with it though
This should help:
from Baer
from Pagid, which is new to me, but good example of the variety of bedding procedures out there.
The best procedure is likely whatever the pad manufacturer you have, recommends. The basic idea is to have a controlled heat up of the pads and rotors to help them 'bond' without getting so hot that the pads or rotors get damaged. For most street applications, it can just be allowed to happen naturally, but the safest/best idea is to always bed the pads in any vehicle.
HTH, »keith
