Aluminum engines with brass components
and hardware in the cooling systems of engines with
aluminum heads and blocks?
These two materials are dissimilar enough that
galvanic corrosion is prone to occur. IIRC, brass is
the more cathodic or 'noble' while aluminum is the
more anodic or sacrificial. Put 'em together, add an
electrolyte (the coolant) and watch the aluminum rot
away.
I noticed today that my aluminum radiator has a
brass petcock. My old 525 received a brass
thermostat to replace a galvanized . I've seem
several photos here of aluminum blocks with brass
freeze plugs.
What gives here? Have the elements been rearranged
on the periodic table or are people unaware of the
consequences of such actions?
I work in the aerospace industry and we use alumnium and brass together on lots of things and the brass is usually the first of the 2 metals to corrode...Remember, the alumnium found in heads, radiators and such aren't pure alumnium, they are alloys and these alloys are much less prone to galvanic and electrolytic corrosion than pure alumnium
occur.
- dissimilar metals
- conductive path
- an ion path from the anode to the cathode
materials and the large the cathode is compared to an
anode, the more pronounced corrosion will be.
With an anodic index of 0.85 V, mild steel appears to
be much closer to conventional wrought or cast
aluminum (0.90-0.95 V) than is brass or bronze
(0.40-0.45 V).
Aluminum, steel and iron are toward the anodic end of
the chart and are sacrificial (they rot away) relative
to brass which is toward the cathodic end of the chart.
Coolant when new is pretty benign, but in time it can
become much more conductive.
Reducing or eliminating the dissimilarites between
materials is ideal. Freeze plugs are, or used to be
available in steel as well as brass. As you mentioned,
petcocks are available in steel and suitable plastic,
too, I believe. In at least some cases, thermostats
are available in steel.
Coatings can interupt the paths and prevent or slow
corrosion. We see this in use on the U-joints for
the aluminum drive and half-shafts.
Keeping the coolant fresh reduces or eliminates its
conductive role in corrosion.
Here are a couple of short, informative discourses on
the matter. Searches will turn up many others.
Galvanic Corrosion by Dr. Stephen C. Dexter.
Galvanic Compatibility Unknown - (Engineers Edge).
I know there's a potential for problems. I don't have
the answers. I'd wondered about the things I've seen
done as folks make changes to the OEM configurations
and I thought I would raise a flag.
new six cylinders ...
reviewed and it was a key reason why the car was
not our list when we bought new this fall.
I have learned the hard way - three times, in fact,
that BMW and I have different expectations of the
cooling system.
as a sacrificial anode. Does anyone have a good
source for these?
year. In that case, Zinc was mentioned.
Someone mentioned that this is used for boat
protection amd can be sourced from marine supply
houses. It was indicated that placing the material
in the coolant passage would be insufficient for
conductivity. There was a reply that the material
could be tightened into an unused sensor hole.
If I locate the post, I will add a link.
Turcotte for two columns Bedard wrote in C&D in June
and July of 2002.
I agree about the role of coolant but they are talking
about stock configurations. I wrote out of concern
about cases where parts are changed for ones made
of different materials with the result of unwittingly
increasing the tendency toward corrosion (and
making the job of coolant more difficult.)
I thought the following remark was interesting.
extended-life coolants for 10 years, and some of
what he’s learned has convinced him that the two
most important cooling system maintenance items
are freeze point and proper coolant level.
conclusions in much less than ten years time.)
Thanks,
Ken R.
Lead acid batteries work based on this potential.
Your heads will conduct plenty well to the block through the head bolts and head gasket, which is partly metalllic.
http://www.penray.com/hdcatalog/liquid3000.htm
appear to be popular with the HD diesel crowd. I did
not find any negative remarks, nor anything counselling
against use in gasoline applications in this brief research.
Also, while looking into the Pencool, I came across a
reminder about how the introduction of new/virgin
aluminum such as a replacement radiator, heads,
intake and/or water pump increases the consumption
of the SCAs (corrosion inhibitors) in the coolant until
such time as the normal coating of oxidation forms
on the surfaces of the passageways that the coolant
moves through. This means to me that the coolant
should be replaced earlier or additional SCA should
be added to help replentish the inhibitors.
Thanks,
Ken R.
Thanks,
Ken R.
an SCA (SCA - Supplemental Coolant Additive), as
opposed to an alternative coolant (as I initially mistook
it to be.)
Also, the intent isn't that it is included with new
coolant, rather it is added to existing coolant as part
of routine (annual) maintenace during the lifecycle of
the coolant. IIUC, the coolant is still replaced on a
periodic basis.
Others would want to verify this interpretation and
see whether they come to the same conclusion.
I wonder whether it has any perceptible negative
effect on cooling performance. You mention that
engines with it show no build-up inside so I'd suppose
cooling would be the same/better compared to an
engine without this maintenance.
electrical potential, that can't just be shorted
out against each other.
specifically about use of a cable between Al heads and
an iron block - or about the concern over mixing
dissimilar metals when reassembling with new parts.
