Dexcool in LT1?
Old Dec 3, 2005 | 09:24 AM
Aurora40's Avatar
Aurora40
Originally Posted by REDC4CORVETTE
I have had the Orange stuff in my 94 for 3 years and no problems .
I don't mix it with anything 100%.
What's the rational behind not diluting it 50/50? It's your car, and if it works for you... But it won't transfer heat as well when not diluted, it probably won't have as good freeze protection, and supposedly Dex-Cool can be rather caustic when not diluted properly.
You might consider running it 50/50 instead.
Old Dec 5, 2005 | 06:33 AM
Atok's Avatar
Atok
Pure distilled water will conduct heat better than any mix of antifreeze. That's why race cars use only water under high pressure (sometimes with an additive like water-wetter). 50/50 antifreeze is better in street cars because it's a good comprimise between boil over/freeze protection and provides adequate heat transfer. 100% antifreeze does not transfer heat very well at all, your car will run hotter if you run 100%.
Old Dec 25, 2005 | 09:14 PM
SUNNYD 95's Avatar
SUNNYD 95
Default Green stuff
Originally Posted by Atok
If this is true then they must have switched sometime during the year, because my '95 came with the green stuff.
If you are going to change it, be sure to do a good flush including removing the knock sensors to drain the block. Fill with clean water, run the engine to warm it up, drain and repeat a few times.
[Edit]
Just checked my Service Manual. Page 6B-6...."Use a 50/50 mixture of high-quality ethylene glycol antifreeze, GM specification 1825-M..."
That's the green stuff. So it looks to me like '96 is the first year for Dexcool in Vettes.
I have a 95 and mine came with the green stuff so thats what I'll put back in after a flush
Old Dec 26, 2005 | 12:50 AM
groundhawg's Avatar
groundhawg
Dexcool is good stuff, but like any other products; one needs to knows it limitation in its use. I've been using Dexcool on My Vette for several years, with no problems. See attached link on Dexcool usage:
http://www.imcool.com/articles/antif...l-macs2001.htm
Biggest thing is to flush you system out, replace your radiator cap, and keep the mixture at a 50-50. If you use a less the 50-50, add some additional inhibitors like WaterWetter(r) from RedLine.
If you are converting from te green stuff for the first time, don't wait 5 years to change it. Change the initial changeout fluid after 2 years, then you can do it in 5 years intervals afterward. I don't care how well you flush the system out during the initial changeover, you'll never get all the green stuff out. There will always be some residuals.
Dexcool is getting a bad rep because people continue to pour the green stuff into a radiator system filled with Dexcool.
Or you can just forget it all and just stay with the green stuff. At least it's not being phased out like the Ozone-Depleting based Freon.
Old Dec 26, 2005 | 11:59 AM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
Originally Posted by Corvette Kid NC
As a professional wrench for over 30 years, I wouldn't use it in anything. But that's as close as I'll come to getting involved in this potential argument.
