Location Set Timing connector '89 L98
Old Dec 2, 2005 | 09:16 PM
david srour's Avatar
david srour
Default Location Set Timing connector '89 L98
Disconnect SET TIMING connector (tan/black wire) located in harness close to distributor. DO NOT disconnect 4 wire connector at distributor.
This is from All Data site. Could not locate where the connector is. tx
Old Dec 2, 2005 | 09:27 PM
CFI-EFI's Avatar
CFI-EFI
On my car it is just to the right of the brake booster. You really are going to need a factory service manual. www.helminc.com
RACE ON!!!
Old Dec 2, 2005 | 09:34 PM
cv67's Avatar
cv67
St. Jude Donor '05
Default Hey, Jim,
How have you been , haven't talked to you in awhile. ..Hope you are hanging in there,. Any idea what code 42 is? Ran a search, came up with mentions of codes, but nothing specific.
What's the best way to reset the TV cable. Because I had it apart 9intake off) it shouldnt need to be reset, should it?
Old Dec 2, 2005 | 09:46 PM
bogus's Avatar
bogus
CFI-EFI is right... however... the connector moves around from time to time.
I have found it near the booster, I have seen them nearer the firewall. You just have to go looking for it.
Old Dec 2, 2005 | 10:32 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
hope this clears up your question. it is the connector with brown wire just behind the white wire.
Old Dec 2, 2005 | 11:13 PM
david srour
found it. thanks!
Old Dec 2, 2005 | 11:51 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Hey sleazy,your valve covers are screaming for a repaint!
Old Dec 2, 2005 | 11:55 PM
Sleazy Rider
paint hell...they want billet aluminum
Old Dec 3, 2005 | 12:04 AM
Aggravated4life
Even better!
Old Dec 3, 2005 | 01:49 PM
Sleazy Rider
they'll match the rest of the engine, and finish out the a/c lines
To Location Set Timing connector '89 L98
