Battery indicator lit
Battery fairly new (<6mos).
Did I lose alternator, or should I be looking somewhere else?
Any advice is appreciated.
Its not uncommon for new batteries to start going bad sometimes,even when you had it off for a few days.When I worked for a few Dealers,we had new cars on the lot with alot of bad batteries.If the charge wouldnt hold anymore,we would swap the battery out.
Also,Can you hear any noise from the alternator?Have you taken the belt off and see how it sounds/feels by spinning the pulley by hand?Those are things I do before swapping out alternators.Thats not always a sure fire way to check for problems with an alternator but a start at home.
Also,if you do change the alternator,be sure the battery is FULLY charged before starting the car back up.
