1984 Corvette Cross Fire Idle Problem Cold
As Dom said, check the TB lid and also the TB gaskets and make sure the TBs are balanced. You will need a manomenter to balance the TBs which you can make with a yard stick and some 1/4 inch clear tubing. Here is a link to the procedure at the Crossfire Forum. You can also do a search there on what the manometer looks like. Just follow the procedure.
I use a 1227747 ECM from a 88-93 TBI truck for tuning.I highly recommend the Crossfire forum for info. Great bunch of people (as with this forum) and lots of good info. And as you can imagine a few opinions.
Here are the motor specs.
Block - 95 4 bolt roller
0 Decked
Quench Distance - 0.039"
Rotating Assy - Eagle stroker kit (Crank, Rods etc)
Speed Pro Pistons with -12.5 cc D Dished
Moly Rings
Internally balanced
6 3/4 Inch harmonic balancer from Summit
Scat flexplate for late model block
Heads are TrickFlow 195cc intake runners with 64cc chambers
Compression ratio 10.4:1
Cam - Compcams CS XR269HR-12 (pn 08-502-8)
Duration @ 0.05 218/228
LSA 112
Lift with 1.5 Rockers - .495/.503
Lift with 1.6 Rockers - .528/.536 (I did this)
Summit Roller Lifters
Aluminum Roller Rockers 1.6 ratio (from ProComp in Australia)
XRam with 2.13" TBs and 90 lb Injectors (454 Truck)
Headers - 1 3/4" Tubes, Exotic Muscle (www.exoticmuscle.com)
I like my 84 alot as well. The best part is keeping up with the folks who snub their nose at the 84 (please no debates) and beating them from time to time at the track.
check out the Crossfire and Thirdgen websites.
Some of what you describe are 'computer design
issues', such as, decel fuel cutoff, decel fuel enleanment,
desired idle speed, idle stall catcher,
desired open loop a/f ratio, etc....
assuming you don't want to mess with
the computer...
check for vacuum leaks,
try disconnecting EGR / for a test,
check for leaking or imbalanced fuel injectors,
ensure that the spark plugs are perfect,
try lower octane gasoline
IMO, the General, probably for reasons
of emissions and fuel economy,
made some 'driveability' tradeoffs
that push the car to a tendency
to stall, that is just the way it is,
anything that will help driveability,
will reduce stalling.
the computer...
The Xfire certainly had its share of compromises. Like the size of the ports on the intake side of the cylinder heads, not to mention the heads themselves. The quirky staggered injector setup to make up for the drop in FP between the 2 TB's. But for the most part, the car runs pretty well and if it isn't, then the problems are pretty much like any other SBC. Its a vacuum leak, or plugged fuel filter or something like that. The injectors or IACs may need to be cleaned. Put a timing light on the car and shine it on the injector spray. Try putting the induction lead for the timing light on #3 CYL, I think it works better for the injectors. See if the spray pattern is conical or is it sputtering out. The Xfire manifold uses heat to help vaporize the fuel. Unlike the TPI, the Xfire is a wet manifold. So the hotter the motor the better the atomization which is why it drives better when its warmed up.
84's are cool, hope you have fun with it.
