NEW! Exhaust system from Random Tech. What do u guys think?
Old Dec 4, 2005 | 04:44 PM
88BlackZ-51's Avatar
88BlackZ-51
Default NEW! Exhaust system from Random Tech. What do u guys think?
http://jeff.vettextc.net/exhaust/Random-X-pipe.jpg
It looks good, and I dont know how much yet.
Old Dec 4, 2005 | 05:02 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Sweet! It won't be cheap.
Old Dec 4, 2005 | 05:34 PM
mseven's Avatar
mseven
I think it looks good and I insatalled this set-up on mine. There are some issues with it, beacuse it is for an L98 set up only one hanger on one side to support the weight of both pipes other than the muffler hangers in the back. This allows the long pipe to try and twist a bit , even w/heavy duty band clamps cranked.
System in no way will go on using 2149 's having the x pipe first, the collector extension on drivers side is on trans linkage (which will need to bent up some). Setting up bullits first will work (which is fine anyways) pipes will need to be persuaded to fit together at X.
You will ultimately need to have tabs welded to use the LT-1 brackets/hangers and I also welded it at the x so it could not twist(the x then stops that)
It does look good and sounds good, as to power, I can't honestly tell you because I did way to many mods. at one time.
Old Dec 4, 2005 | 06:11 PM
thirdtimevetteowner's Avatar
thirdtimevetteowner
What mufflers are you running with the random tech system?
Rich K
Old Dec 4, 2005 | 06:18 PM
mseven's Avatar
mseven
Right now and subject to change, I have dyna max super turbos, I wanted quiet....quiter. The system sounds pretty good
*edit* I should mention here that I expected the system to fit up better, but the construction and quality is excellent, just needs some tweaking
Old Dec 4, 2005 | 11:24 PM
Slalom4me's Avatar
Slalom4me
Originally Posted by 88BlackZ-51
It looks good, and I don't know how much yet.
mseven posted prices back in Oct
Originally Posted by mseven
PN# 181-30915 SHF cat conv.(includes 2 bullits, all pipes and"x") $647.51
PN# 33-130902 3" SS extension Pipe (assy. for hooker w/flange) $215.84
This does not include band clamps, and $25.00 shipping
Not cheap, but very well made pieces
Here are some other links. They have the R-T system as well as lots
of examples of what folks have done on their own.
Old Dec 5, 2005 | 08:11 AM
88BlackZ-51
do u have pics? so i have 2149's, and flowmasters out back. Will this system work well?
Old Dec 5, 2005 | 08:34 AM
mseven's Avatar
mseven
I will have pics this week and they will ba posted in my thread on general topics as "got er done". It looks good and it will work well but, as I said the drivers side is not prefect so it takes some playing to clear linkage on an a-4. My collector from the 2149 is right on the heat shield so bolting up that side is a pain. The pass. side is a piece of cake, you will not be able to use the original center trans mount (exhaust) and I haven't figured out how to use the LT piece in there yet. In the back the single support (original) will allow the drivers side pipe to twist at the X. Some fiddeling is required ,and some minimum welding (tabs on pipes in rear for the LT-1 hangers, and welding the tubes to the X only) (Random Tech does not include bandclamps).
It does sound good, and even w/the ST mufflers it has some volume at WOT. All the slip joints were good I did have to get the collector xtensions pumped out a bit to be tighter to the bullits ($5. at muffler shop). Overall mine is relatively quiet I can't tell you how bad it will resonate as I don't have enough drive time on it, but from what I can tell it does have some.
To be honest I just don't/didn't know of anything else that was a bolt up system, everything like TJWONG'S etc. that looked great and perfect fit was all custom that is why I went this way. If you have more questions feel free to PM me
*edit* Slalom4me, Great job of compiling links, way cool!! By the way the system I have does look very similar to jeff's the xpipe is shorter, actually that is were I what originally looking, and he mentioned RT before he provided a link so I callled. I also noticed (on his) if you have a 6speed, you will have a lot more room on the drivers side than me
Old Dec 5, 2005 | 11:35 AM
88BlackZ-51
do u think more room with a 4+3?
i sent u a pm.
Old Dec 5, 2005 | 11:44 AM
bogus's Avatar
bogus
nice looking system....
Old Dec 5, 2005 | 01:33 PM
mseven's Avatar
mseven
i sent u a pm.
Got it, PM sent
Judging by pics -=jeff=- and others, as I don't own a 6 or 7 speed, looks like about 3" more available on drivers side w6speed, again this is a guess, but he definely has more room to work with than me !
You would need to ask someone who knows more about those dimensions in a 4+3, I can't tell you, sorry
Old Dec 5, 2005 | 08:03 PM
-=Jeff=-'s Avatar
-=Jeff=-
Hey that link:
how did you happen across it? it is in a directory on my web site. I am just curious how you found it.
As for room, with the Zf there is a decent amount of room, but with the 4+3 I am not quite sure on room
Old Dec 5, 2005 | 11:16 PM
Slalom4me's Avatar
Slalom4me
Maybe he saw the pic in your post here and
right-clicked the pic?
I will have pics this week and they will be posted
That would be this thread right here
Old Dec 6, 2005 | 12:41 AM
cv67's Avatar
cv67
St. Jude Donor '05
Nice looking system , but what you already have should do the job.
Old Dec 6, 2005 | 01:12 AM
comp's Avatar
comp
links
Old Dec 8, 2005 | 12:03 PM
BuffC5's Avatar
BuffC5
I love this on my C5...........looks just as nice on the C4
To NEW! Exhaust system from Random Tech. What do u guys think?
