Roller rocker studs/ZZ4 studs
Old Dec 5, 2005 | 02:35 PM
The Bus's Avatar
The Bus
Default Roller rocker studs/ZZ4 studs
The crane roller rocker studs are longer than the stock ZZ4 studs and they bottom out[ in the helicoil] at about the thickness of a lockwasher. Can a lockwasher be used or do I need to cut off some of the bolt???
Old Dec 5, 2005 | 02:43 PM
CFI-EFI's Avatar
CFI-EFI
Would that be the same as the thickness as a push rod guide plate? Are you using giude plates?
RACE ON!!!
Old Dec 5, 2005 | 03:20 PM
The Bus's Avatar
The Bus
Dummy me; You are correct. Got too focused on correct size and overlooked the obvious. Thank you.
To Roller rocker studs/ZZ4 studs
