D44 rear Question
Old Dec 6, 2005 | 10:43 AM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default D44 rear Question
Will a d44 with 3.33 out of a 85 with a 4-3 work in my 93? I just want to make sure that there are no differences other then the gear set.
Old Dec 6, 2005 | 10:53 AM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
it can work, but you will have to either 1) drill the camber rod bracket holes to .50 for the bolts to go through, or 2) use the camber rod brackets from the 85. everything else is pretty much the same, if you are just changing out the center section or bat wing
Old Dec 6, 2005 | 11:03 AM
fsr402's Avatar
fsr402
St. Jude Donor '06
I will be just useing the center and batwing. So just useing those would I still have to drill? I can't remember there being any holes like that in mine. It's been a few years since I had it out.
Old Dec 6, 2005 | 11:15 AM
vader86's Avatar
vader86
3.33 never came in an 85.
3.33 only came in late 89-90 6speeds in the D44.
A 3.31 came in 84, but it was in a D36.
Old Dec 6, 2005 | 11:22 AM
fsr402's Avatar
fsr402
St. Jude Donor '06
hmm, so then what gear would an 85 with the 4-3 have?
Old Dec 6, 2005 | 11:27 AM
fsr402's Avatar
fsr402
St. Jude Donor '06
ok I just found this...
Automatic Transmission
Four-speed Turbo Hydra-Matic (TMH 700-R4)
floor-mounted gear shifter
gear ratios
1st = 3.06:1
2nd = 1.63:1
3rd = 1.00:1
4th = 0.70:1
Rev = 2.29:1
Final drive ratio: 2.73:1
Manual Transmission
Four-speed manual with overdrive
gear ratios
1st = 2.88:1
2nd = 1.91:1
3rd = 1.33:1
4th = 1.00:1
overdrive = 0.67:1
Rev = 2.78:1
Final drive ratio: 3.07:1 (optional 3.31:1)
Planetary overdrive ratios:
2nd = 1.28:1
3rd = 0.89:1
4th = 0.67:1
does this seem right?
Old Dec 6, 2005 | 11:38 AM
vader86's Avatar
vader86
3.07 is what should come in the 85 manuals. What you have there is 84 information.
Old Dec 6, 2005 | 12:20 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I've got an '85 D44 in mine, this is the only mod required. You don't have to go out quite a 1/2", I'll check later and give you the size.
Old Dec 6, 2005 | 01:54 PM
CFI-EFI's Avatar
CFI-EFI
3.07:1. is also what came in the '84 automatics. That chart(?) is a mishmash of info. It has the auto supplied with a 2.73 rear, which was NOT available in 1984 and an optional, for the manual, of 3.31, which was ONLY available in 1984 (optional for both auto or manual). To add insult to injury, the 3.31 gears were only made for the Dana 36.
Although that '85 couldn't have been built with 3.33 gears, neither could the 1993, fsr402 plans to put them in. Just because GM didn't offer it, doesn't mean someone didn't do it.
RACE ON!!!
Old Dec 6, 2005 | 03:05 PM
fsr402's Avatar
fsr402
St. Jude Donor '06
RACE ON!!!
I found a "D44 with 3.33 gears" for sale and I was checking here to make sure one that it would fit and two to make sure this was right. All I really care about is that it will fit and that it IS a D44. I'm going to swap out and have 3.73's put in anyways.
Thanks for the info though. I emailed the guy about the gears, now just waiting to hear back. I knew I could count on you guys to give me the info.
Old Dec 6, 2005 | 08:07 PM
CFI-EFI's Avatar
CFI-EFI
Fact: Any C4 diff will fit any other C4.
Fact: A 1985 4+3 car left the factory with a Dana 44.
Fact: The only C4 rear end available with 3.33 gears was (is) the Dana 44.
Fact: *I* think you will have no problems.
RACE ON!!!
To D44 rear Question
