Anyone using a MSD coil with a L98
Old Dec 6, 2005 | 11:47 PM
GrtWht91's Avatar
GrtWht91
Default Anyone using a MSD coil with a L98
if your using an MSD coil in a L98 is your stock tach off??? Mine is, just wondering if this is normal with a high output coil....thanks
Old Dec 7, 2005 | 01:06 AM
cv67's Avatar
cv67
St. Jude Donor '05
I use one on the 89. If you install the wrong bushing (the little round piece with the spring on it) under it your tach reading will be a little wacky.
Old Dec 7, 2005 | 03:45 AM
AZC4Guy's Avatar
AZC4Guy
I use one... no probs.
Old Dec 7, 2005 | 09:14 AM
GrtWht91's Avatar
GrtWht91
Im using the MSD cap, rotor, and coil, as well as MSD 6AL, and i noticed that RPMS couldnt be right, so i put in the 3000 RPM rev limiter chip and revved it up, and sure enough it limited the rev when the tack showed 4500 RPMS.....i dont know what went wrong.....
To Anyone using a MSD coil with a L98
