Experienced Vette mechanics going nuts!!
Old Dec 7, 2005 | 08:27 PM
Vetracr's Avatar
Vetracr
Default Experienced Vette mechanics going nuts!!
1990 one piece rear seal L-98 race motor runs all day on dyno, no rear seal oil leaks, runs on race track and rear seal leaks like sieve. Inside of bell housing soaked. WHAT COULD CAUSE THIS??? Pro built race L-98 ran at least half a dozen track events before developing a slight rear seal leak, small drop on floor after sitting in garage between races for a few weeks. Big problem developed overnight, went from small leak to soaker in one race weekend. Since then have replaced rear seal several times, including a crank sleeve and an off set seal. Replaced oil pan with race pan. After sleeve and new seal ran on dyno all day, no leaks, went to track, soaks bell housing again!! Crank never turned, good oil pressure. Its not the transmission either, confirmed by changing transmissons. This problem has more than a few Pro mechanics scratching their heads. Leaks on track, not on dyno???
Any thoughts??
Old Dec 7, 2005 | 08:30 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Are you 100% sure it's the seal leaking? Have you checked crank end play lately?
Old Dec 7, 2005 | 08:53 PM
Pete K's Avatar
Pete K
Excessive crankcase pressure? Low tension oil rings and no vacuum pump could cause this. Improperly seated rings could also contribute if it is a leakdown issue.
Old Dec 7, 2005 | 08:54 PM
Pete K's Avatar
Pete K
Could be the galley plugs in the rear of the block. Did the builder seal the threads?
Old Dec 7, 2005 | 09:41 PM
mseven's Avatar
mseven
I agree with this possibility, but I would think the intake, then the front crank seal would be the weakest link and leak first. MO
Old Dec 7, 2005 | 09:46 PM
Pete K's Avatar
Pete K
I have also seen the rear plug behind the cam leak. They have a skinny sealing lip and are the most difficult soft plug to install. I use blue locktite, and smear epoxy around the sealing edge of the plug after I install it.
Old Dec 7, 2005 | 09:48 PM
Pete K's Avatar
Pete K
If it is a scat crank, check this immediately. I had a scat crank ruin a motor due to endplay that increased severly after run in. The thrust surface was a bit rougher than it should have been. Crank was excessively hardened. This made the rough surface work like a file, and it killed the motor.
Old Dec 8, 2005 | 08:23 AM
Vetracr's Avatar
Vetracr
Default Good suggestions guys
Thanks for the suggestions. Because engine has AFR heads with poor oil drain back, engine has two baffled breathers on each valve cover plumbed via large diameter hoses to a single over flow can. I'd be surprised if it was crank case pressure. If it was, I would think it would leak at the pan gasket and front cover before the rear seal. Crank is stock standard size journal Chevrolet mated to original factory block, not line honed. Crank end play is a possibility. How can you check on an assembled engine in car?
BIGGER QUESTION? Why can engine run on dyno under full load, in gear and not leak, yet run on track and leak.
Keep throwing out ideas guys. This one is a stumper.
Old Dec 8, 2005 | 08:54 AM
RacerX70CC's Avatar
RacerX70CC
Stickshift or auto?
In the case of manual transmissions, the constant "in and out" of the clutch will cause the crankshaft to walk back and forth, especially in the case of hard use (track racing, etc.), which takes a heavy toll on the thrust bearing. This is very prevalent on higher mileage engines. Check the endplay of the crankshaft and if it's excessive..the engine has to come out. To check the endplay, you'll need a dial indicator and some means of prying the flywheel or damper (be VERY careful) back and forth.
Good luck!
Old Dec 8, 2005 | 09:03 AM
scnc4's Avatar
scnc4
I see by your picture you are road racing. It doesn`t leak on the dyno when everything is stationary it only leaks when the car has side to side movement and is sloshing oil around in the pan ,leaking into the bellhousing and then after the car becomes stationary Shows up on the ground. I would look at the pan gasket or the piece that holds the rear main seal.
To Experienced Vette mechanics going nuts!!
