'89 running/idleing rough
Old Dec 10, 2005 | 01:00 PM
SunCr's Avatar
SunCr
Grounded (or opened) bypass wire would be a cause of the 42. It's tan/black (mine's mostly tan these days) from terminal C at the 4 way connector at the Distributor to the barrel connector near the battery (you disconnect it to set timing) to Pin D5 at the ECM. You might also want to make sure the plastic barrel connector is in good shape - along with the wire. I usually end up forgetting that the Code is in History after a smog check - The tech will check timing and fail to clear the code and then I'll be scanning it for some other obscure problem and it'll pop up.
Old Dec 10, 2005 | 09:08 PM
Moxxi's Avatar
Moxxi
Default pre cat
Sorry. I still don't understand. I figured y'all were talking about the catalytic converter, but you are saying "Pre" cat. I don't have a clue.
Old Dec 10, 2005 | 10:06 PM
BIG K's Avatar
BIG K
Default '89 running/idleing rough Reply to Thread
Pre- cats are pre-catalytic converters. There are two of them. One coming off of each header prior to the catalytic converter. Either pop your hood and follow pas the headers, or look up from underneith to find them.
Old Dec 15, 2005 | 12:46 PM
Moxxi's Avatar
Moxxi
Default pre cat
Originally Posted by BIG K
1slyder1, do you understand what a clogged pre-cat is from what SunCr has posted?
I still didn't understand at this point. But I went to the General Discussion section of this forum, and asked again. A few other members chimed in, and even included pics.
You can always count on our members to help one another.
