Throwing codes(a lot of them)
Old Dec 8, 2005 | 02:30 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Throwing codes(a lot of them)
Under section 1, the codes are 72 & 74.
What type of code are these?
Under sect. 4 -
15 - Coolant signal below -56 degrees
26 - Quad Driver # 1
28 - Quad Driver # 3
64 - this one I think was caused when I blew a heater hose.
What are Quad Drivers and which coolant sensor is the code 15 saying is bad or has a bad connection?
Old Dec 8, 2005 | 04:08 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Is section 1 the CCM codes and section 4 the ECM codes?
Old Dec 8, 2005 | 06:46 PM
MikeC4's Avatar
MikeC4
here is a vague, but informative description of Quad drivers:
http://www.troublecodes.net/articles/quaddriver.shtml
Old Dec 8, 2005 | 07:03 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Thanks, that tells what a Quad driver is; but not what devices drivers #1 and #3 control. But it atleasts points me in a direction to look, just wish it didn't confrm the my ECM is shot.
Old Dec 8, 2005 | 07:12 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
If I remember right quad drivers are the ECM.Looks like your ECM bit the big one to me.
Old Dec 8, 2005 | 07:21 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Right, but according to the link MikeC4 gave me, it also means I have a short or a bad device that those drivers control.
So, Red for the $64k dollar question; can you tell me what devices those 2 drivers control?
Old Dec 8, 2005 | 07:32 PM
ittlfly's Avatar
ittlfly
Driver # 1 senses: canister purge, EGR solenoid and AIR relay (pump)
Driver # 3 senses: A/c clutch relay, fan relay #1 and fan relay # 2.
Old Dec 8, 2005 | 07:36 PM
Redeasysport
From what I have seen that many things can't go bad at once.You have seen this before
http://forums.corvetteforum.com/show...m_id=48&arch=1
My bet is your ECM is bad but you can try OHMing the wires for shorts.
Old Dec 8, 2005 | 08:23 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
OOPS, my bad. Forgot all about getting the 28 code before, but in my defence( not much of one), once I replaced the battery; I never got that code again till right after my heater hose broke and now almost everytime I start my car the 'service' light starts flashing.
I am going to clean all my connections this weekend and where is a good place to get another ECM?
Mine is a DD, so I cannot wait to have mine rebuilt.
Thanks Red, even though you helped me make look real DUMB!!
Old Dec 8, 2005 | 08:27 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Now that I showed my lack of memory, what are CCM errors 72 and 74?
Old Dec 8, 2005 | 08:55 PM
Redeasysport
Did not mean to make you look dumb just jog your memory.At my age it needs it once in a while.Autozone has reman ECM's I believe.
Old Dec 8, 2005 | 09:16 PM
Redeasysport
This might help:
The H means its a history code. The 72 and 74 are codes associated with the dimming circuit. Here's the tech info on it... http://www.corvetteforum.net/c4/dave8476/index4.shtml Here is the simple fix... If "SYS" is displayed in the LCD section of the instrument panel cluster after the customer installs a new stereo, he will need to do the following:
1. Buy (2) 1 kilo-ohm 1/2 Watt resistors. [Radio Shack part # 271-023. They sell them as a 2-pack for 29 cents.]
2. Disconnect the negative battery cable.
3. Remove the receiver.
4. Connect one end of both resistors to ignition power. (Yellow wire in the car.)
5. Connect the other end of one resistor to the purple/white wire in the car.
6. Connect the other end of the second resistor to the grey/black wire in the car.
7. Cover all connections and completely cover the resistors.
8. Reconnect the negative battery cable
:yesnod
Old Dec 8, 2005 | 10:58 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
But I still have Bose Gold installed.
I know you didn't and yes I am getting up there too.
Old Dec 9, 2005 | 08:54 AM
ittlfly's Avatar
ittlfly
I don't have my Helms in front of me right now, but the CCM also senses the "bells and whistles" in additon to the radio. Check to see all your fuses are good. Be sure all your accessories are working ie: dash dimming, courtsey lamps, etc. Maybe someone will jump in with the CCM codes for you. I'm getting up there too.
Old Dec 9, 2005 | 10:21 AM
Redeasysport
When I scanned my car recently I had an H74 my self never had any symptoms so I figure I had an intemittan connection in my dash.It may mean nothing.
Old Dec 9, 2005 | 10:48 AM
WEH 2000C5's Avatar
WEH 2000C5
Great info "Redeasysport" Thank you for the schematic. A lurker
Warren.
Old Dec 9, 2005 | 12:13 PM
luvmy92's Avatar
luvmy92
Hey Randy,
the code 15 is the coolant temp sensor in the water pump. I was getting that and had Norris replace the sensor. The day I got it back I was still getting the code. Turned out to be the piggyback harness connector in the waterpump. It needed to be replaced and that solved it.
Mike
Old Dec 14, 2005 | 11:31 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
Thanks Mike, I will look into that.
My dimmer works fine and I can't find a blown fuse, but I am going to take my radio out this weekend. So I will clean my connections and see if that helps.
To Throwing codes(a lot of them)
