Accel Injectors, Good Idea, Or Bad??
Location: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
1 Post
I need some new injectors. I am thinking about the accels.
the car is pretty much stock. Accel wants a little over $250.00
for a set of 8, O'reilly wants $77.00 a piece for replacements
($616.00) someone steer me in the right direction
95 LT1
95 LT1
Large Impressive Member
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I've seen a lot of negative feedback on the Accels. The Ford Motorsports ones should be cheaper than the Accels and are of good quality.
Received 1,423 Likes
Wouldnt touch em.
1 Post
Originally Posted by Corvette Kid NC
The Ford Motorsports ones should be cheaper than the Accels .
I know I need just stock size, but what is stock size??
I was also told to use the SVO's, I think those are ford right??
I still need to know injector size>
I should have mentioned before, I got a set of low mileage LS6 take-offs over in the C5 section for $60. I think LS1 and LS6 are the same injector. Only about a pound or so more when run at the LT1's stock pressure which won't hurt a thing.
95 LT1
95 LT1
http://www.fiveomotorsport.com/Injector_SetsTPI.asp
Try here, good prices, check em out!
How do I find out what fords to get, and what size??
SVO 30lb injectors are good for about 450rwhp. Most on this list don't need bigger.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
VERY BAD IDEA
I bought a set from Mid-America. Car ran like horse crap, put them back in the box and got my $$$$ back.
Ex-wife has been running a set of Accel 24 lb injectors on a L-98 383 stroker for 3 years no sweat. Just like with anything, your results may very. If they were all bad then they would be out of business. The technology is pretty much the same across the board and the whole auto parts industry is prostituted out anyway. Only a few manufacturers selling and buying from each other. Just my .02
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
95 LT1
95 LT1
St. Jude Donor '10-'11-'12-'13
1 Post
I will say I have true duel's and no smog (or cats)
egr block off plates, electric W/P with gear
removed from behind timing cover, true roller
T/C. I'm not sure if injector size matters with such
small mod's. I was thinking of installing a CC 305 cam
later, so will 30lbs matter later for performance??
And I have stock heads.
Accels...
Installed a set of new 36 pounders...at the 10,000 mile mark-one failed in the open position.
Replaced with another new 36 pounder...another different one failed within another 1000 miles...this time in the close position.
Different cylinders...OEM harness.
I would not recommend Accel for injectors...
I replaced with a set of Delphi 32 pounders bought from Racetronix-forum sponsor. GM issued injectors on the new cars.
Very happy.
Very happy.
Originally Posted by TM-96CE
SVO is the old name for Ford's Special Vehicle Operations (performance division). That name changed to SVT - Special Vehicle Team.
And by the way, I have accels with probably 10,000 miles on them and have no problems, but then again, I have lots of problems with my 85, so who knows- they could be bad too and just disguised by other issues!
Last edited by eric_daniel; 12-10-2005 at 09:25 AM. Reason: forgot reason for original post!!!!
So I can run 30lb's with no problem??
