Need Speedo Gear....Suggestions?
This is what the local shops told me when I inquired about a gear change.
Sorry.
Larry
code5coupe
Sorry.
Larry
code5coupe
- You have to program the ECM for your new gear set. You can also do some minor tuning while your at it (re-program the fans, adjust timing, adjust a/f ratio, etc....)
RACE ON!!!
A 4.10 axle ratio with a 15 tooth drive gear would require a 48 tooth gear with a 315 tire! There is NOT one available from GM. With out a change of the DRIVE gear speedometer correction is NOT done with a DRIVEN only change. DRM and Lingenfelter might still offer the package but it was pricey $145 comes to mind. An electonic ratio adapter is about the only "practical" solution.
People struggle with some of these Dakota and Abbott. The real fix I believe might be a Terf branded adapter.
RACE ON!!!
Price: $75
http://madz28.com/9697.php
BTW I'm still waiting your call!
I'm pretty comfortable with my "statements" since everything was directed to "one" car and a specific ratio change! A GS with 315 tires.
** I believe the error with the 45 is closer to 10%
I didn't even consider the OBD2 "factor" here and if it can be done with programming it would have likely been the "only" recommended procedure.
I did a ZF cable drive conversion for a "young fellow" with a ZF in an '85 Monte Carlo with 3.73's recently. He had no speedo for some time. The chassis dyno said I passed the test and "the Judge" approved also! He had been told he needed an electronic to cable drive box ($150 plus install). I accomplished his with an old style sleeve and gear combination. His cable actually ended up being long enough. He was done with less than $50 in new parts. The 5.7 and ZF "black label" in his car with the 3.73 gear is an interesting car to drive.
Thanks for the support! Here's a link to his site with the information and pricing! The information "confirms" my calculations with the change to a 13 drive etc! Ole "grease gear breath" I guess didn't do to bad here! Be sure to see my reply to Sam(65Coop) ..... I asked and she said "It isn't so"!!!
http://www.zr1specialist.com/HAT%20W...on%20Gears.htm
Still if with an OBD2 and a ZF the calibration can be done with programming I believe it would be the way to "fly"!
Let's see you justify, "would require a 48 tooth gear with a 315 tire" that the section width, stock or otherwise affect the speeometer reading.
After spouting, "With out a change of the DRIVE gear speedometer correction is NOT done with a DRIVEN only change.", how do explain GM using only two different drive gear tooth counts with seven different rear axle ratios?
I never suggested that there weren't other ways to correct the speedometer. I popped up with a simple, inexpensive solution and you come back with WRONG and cite nonsense as to why I'm wrong. It's great that you are comfortable, I for one am happy for you. Now make the rest of us comfortable, namely me, with some justifications for your challenged statements.
RACE ON!!!
In light of your declaration, "would require a 48 tooth gear with a 315 tire", let's see you justify, that the section width, stock or otherwise, alone, affects the speeometer reading.
RACE ON!!!
It's a GS Coupe (assumed) Factory tire (assumed) 31535/17 ! 315 is merely a reference to the "tire"! Tire roll-out (revolutions per mile) on a 31535/17 is something at 785.
Formula: drive gear (15) X ratio (4.11) X tire roll out (785) / revolutions per mile used to calibrate the head (1000)= driven gear (48.3) That's how I did it and I believe it to be pretty accurate. Here's a link that pretty much confirms it! Some divide by 1001, I know not why! A cushion maybe! ATI uses this I believe. Since this is a digital "read" and electronic the 1000 could be replaced by maybe pulses and change the calculation a bit, but you asked "comfortable" and I am with that #!
http://www.bgsoflex.com/speedo1.html
There was "no nonsense" cited and my reference to "drive and driven replacement" was pointed to "this application"! The use of the two gears you mention for manual trans C4 applications is correct but all axle ratios and tire sizes "fit" the available desired drive/driven combinations that could be compiled with GM existing parts. Through about 3.75 axle, driven (only) changes will generally do when using tire diameters used in production or "similar" diameters. Get wild with "tire" diameter and it "all" changes again!
Your reference "about 5%" I believe is flawed by almost 2 times. The error is something I'd say nearer 9+%.
I didn't see "GS348" anywhere stipulate "inexpensive" or just a WAG!
He did ask simple or PITA!
1. If it can be done with programming "simple", the expense seems resonable.
2. If it needed to be done with gears, depending upon one's skills "simple"!
3. An electronic box, if your one to play with the rear gears "frequently" and there are those, maybe it's the better buy. Again the cost "reasonable" depending on one's "skills"!
If it were a job one needed to "hire out" regardless of the method the price other than programming "escalates"!
Everything I stated was regarding this "one single" axle ratio change on this car with some "assumed" factory equipment (3.45 gear, 31535/17 tire)
There was never an intention to "attack you"! Perhaps I shouldn't have SHOUTED!!!!
NUFF said! I'll close with your "RACE ON"!
okay?
Now you can continue the debate
I "LEARNED" that's cool It was a "tough" lesson!!!!!!!!!
Here are two simple, straight forward, questions, based on your declarations.
1.) In light of your statement, "...would require a 48 tooth gear with a 315 tire!", please explain how section width, alone, will affect a speedometer reading.
2.) In light of your statement, "With out a change of the DRIVE gear speedometer correction is NOT done with a DRIVEN only change.", how do you explain GM using no less than 7 gear ratios with only 2 drive gear tooth counts?
You can step up the the plate and defend your statements or you can dance some more.
That ought to be clear and easy enough.
RACE ON!!!
I've never heard that one!!
