Morning Sickness
Old Dec 9, 2005 | 07:45 PM
bogus's Avatar
bogus
Default Morning Sickness
Ugh... I just tried using search, and all the "archived" links came back with no link... helpful, eh?
Here is my question: Internal to the rack and pinion (or PS pump for that matter) what is failing when morning sickness begins?
Is it a seal problem? Is it a problem with the internal diverter valving? Is the pump failing in some way? It's always blamed on the rack...
I read a post recently where Seafoam has a product that would help fix this. Would this be the Seafoam Transmission flush? It would make sense.
The reason for these questions is that morning sickness has attacked my 92 Coupe. I may try the Seafoam and flush it out...
For those of you aware, the BG power flush is nice, but I don't know if the fluid would really get rid of enough goo to do anything.
About 20 years ago, I owned an AMC Pacer... my first car. A real date machine... However, the rack on it failed, but it's death was easily diagnosed. The bellows on the rack dry rotted and allowed dirt to enter the shaft. This tore up the internal seals causing pressure loss and severe leaking. BTW, these racks were GM sourced - Saganaw...
Any insights would be greatly appreciated!!
Old Dec 9, 2005 | 08:30 PM
_twisted_'s Avatar
_twisted_
I write up a nice tech tip and this is the way your treat a brother?
Where's the love?
domesticmisfits.com
Old Dec 9, 2005 | 08:32 PM
bogus's Avatar
bogus
gee... I feel so bad.
Old Dec 9, 2005 | 10:03 PM
lite blue's Avatar
lite blue
St. Jude Donor '12
It's the internal seals. Go get a rebuilt rack at the parts store and change it out. It's some work, but no big deal.
And flush everything while you are at it.
With good PS fluid.
Old Dec 9, 2005 | 10:20 PM
vader86's Avatar
vader86
yes it is the seals themselves that are deteriorating, nothing to do with the pump at all, though i suspect that the crap thats in the system will eventually kill a pump
Old Dec 9, 2005 | 10:47 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I thought when they said the rack's gone, it meant the seals and the pump, too. Is that not so? Don't know about C4 pumps, but know that quite a few other cars have weak pumps which frequently go out. Info would be appreciated.
Old Dec 9, 2005 | 10:48 PM
cv67's Avatar
cv67
St. Jude Donor '05
89's got the funk, too. Curious to see feedback on rebuilt racks.
Old Dec 9, 2005 | 10:53 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
A good flush and it should be good to go for a long time,unless its really bad.I had the morning sickness and flushed the rack and pump,added new fluid and it was good for 5 more years until I replaced the rack and pump one day.The pump was still good but I figured I might as well change that while I was at it.Only on the coldest days did I notice it being a little tight until it warmed up.
If the flush and fill doesnt work,then its def. time for a new rack.
Old Dec 9, 2005 | 11:22 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Gordon Killebrew says to use a certian product to soften the seals. He says it usually works. I have a can out in the pole barn but it is so friggin cold out there that I am just too dang warm here in the house to go look.
I can't remember the name of the product right now. I will look tomorrow when it gets above 20 degrees.
Old Dec 9, 2005 | 11:24 PM
Casethecorvetteman's Avatar
Casethecorvetteman
Sounds to me like a contraception issue mate
Old Dec 9, 2005 | 11:28 PM
Casethecorvetteman
Does this make you feel warmer Ron? Id really love to know what that product is for future reference....
Old Dec 9, 2005 | 11:54 PM
bogus's Avatar
bogus
I have already done a rack swap... so the act doesn't scare me, I was just saving the $$$ during the holidays!
I did the swap in McShaggers 92 a few months back. It's a one day job, and having done it, could do it quicker. It's not bad, really, just need some crows feet and a tie rod removal tool.
So it is seal failure... interesting. I am gonna try a flush... I can't see the harm. I nothing else, the pump will be happier for it.
Old Dec 10, 2005 | 01:53 AM
RatC4's Avatar
RatC4
Here's my experience. The steering would feel unboosted first start of the day. After one three point turn, it felt fine. I drained the fluid out of the reservoir and replaced it with the Lucas additive and the problem was gone. After about six months I flushed the system with regular p.s. fluid and refilled it without the Lucas. Now the first few turns of the wheel are somewhat stiff but not bad. I think it is worn bushings in the rack that just need a good coat of oil on the before they smooth out. I bet the Lucas additive stays on the bushings better and thats why it seems to solve the problem.
Old Dec 10, 2005 | 11:13 AM
corvetteronw
Cruise-In VIII
Andy, the product is made by Lucas and is intended to stop leaks and soften the seals on power steering racks. The label says it is guaranteed or your money back. Gordon recommends adding some even if you are not having any problems just as a preventitive measure. I went out to the pole barn anyway for ya even though it is only up to 18 degrees.
Case - that is a pic I got from a Google search for "blizzard". I have a machine in my garage that is called a snow blower. Yesterday I blew 8" of snow off my cul-de-sac. It is a private street so the city snow plows don't touch it. All of the home owners on my street own snowblowers and we all pitch in and clear the snow after a storm. I ended up covered in about 1/4" of frozen white stuff as it blows back all over you when the wind hits the snow coming out of the chute. You ain't missing a thing!
Old Dec 10, 2005 | 12:20 PM
_twisted_'s Avatar
_twisted_
I used the Lucas stuff, its a lot thicker then ps fluid.
If you live in a cold climate, keep the lucas in the house overnight to make it flow out of the bottle easier.
With that in mind, the added viscosity actually made my ps pump starve in 20* weather for a few seconds, well after I put the lucas in(months) Just something to think about.
Old Dec 10, 2005 | 12:22 PM
bogus's Avatar
bogus
Sadly, I am familier with this concept of "snow." I am painfully aware of what a "snow blower" does... and gleeful in the reality that will never encounter either in my neck of the woods.
I will check out the Lucas stuff!!!!
Old Dec 10, 2005 | 12:23 PM
bogus's Avatar
bogus
Is this the additive or a replacement fluid? I will check it out... I live in SoCal, so I don't have to fret 20* weather.
To Morning Sickness
Old Dec 10, 2005 | 12:47 PM
comp's Avatar
comp
did you add the whole bottle at one time ????
Old Dec 10, 2005 | 03:27 PM
viii's Avatar
viii
I agree with the concern about the added viscosity. I put lucas fluid in my other gm vehicle with morning sickness, and now with the temps in the single digits, the pump/belt squeal like a pig for a good 15-20 seconds. I removed the power steering fluid and replaced with the regular stuff and what a difference. the lucas produce may help some problems but may also create new ones when it gets super cold.
Old Dec 10, 2005 | 07:23 PM
Casethecorvetteman
Arrrrr yes, we do have that same brand of oil aditives and stabilizers here in Australia as well. As for the snow, it couldnt happen here!! 40-45*F is about as cold as it gets here in winter,so it looks just like my pic (taken from my front yard) all year round(unless its raining)
