Elec. Short
Old Dec 10, 2005 | 11:38 AM
jchanney's Avatar
jchanney
2nd Gear
Default Elec. Short
1993 40 anniv.Corvette I have a electrical short that is killing the battery.
I believe it could be the motors for the headlights. When the 60 amp fuse is installed the left headlight motor spins for a short while. A strong spark can be seen and the battery will be dead in 2 days. Does anybody know how this can be traced or where a wiring schemetic can be found to help. what controls the timing of the motors and turns them on and off?
Joe
jchanney@comcast.net
Old Dec 10, 2005 | 12:20 PM
bogus's Avatar
bogus
what year?
If you have a short, and have isolated it to a specific circuit, your only hope is to trace the wires associated.
To do this effectively, you need the helm factory service manual - www.helminc.com
sometimes, you can find used copies for sale here or on ebay.
Old Dec 10, 2005 | 12:44 PM
CFI-EFI's Avatar
CFI-EFI
Joe
What's to trace? Fix the head light motor. As stated, there is a wiring schematic is in your factory service manual.
RACE ON!!!
Old Dec 10, 2005 | 03:28 PM
Slalom4me's Avatar
Slalom4me
Have a look to see whether these help at all. The first one seems to
describe similar motor run-on symptoms.
Headlight bushing repair (2004-01-18)
Headlight motor repair / Bushing replacement (06/08/01)
There're other topics of interest in the area, too. Tech Tips
Old Dec 10, 2005 | 05:11 PM
Bruce's Avatar
Bruce
Are you happened to have a Optima battery? if it is than the battery is the problem. The top post is hitting the ecm bracket causing to drained the battery. I have optima on my 93 everything seems to work fine just awhile. All the certain my optima are weaker and weaker. I thought I have a bad optima. I brought the battery back to the store and have them checked. They told me I got a good battery. I then reinstall the battery the battery and found the top post + post is hitting the bracket that I some time hearing sparking noise but did not know where the heck the arcking noise come from. I put in a new battery without the top posts. Solved all my battery drain problems.
Old Dec 10, 2005 | 09:28 PM
VenkmanP's Avatar
VenkmanP
Where do you see the spark?
To Elec. Short
