rear caliper
Old Dec 10, 2005 | 11:58 AM
8888vette's Avatar
8888vette
Default rear caliper
i am in the process of replacing my rear rotors my question is do i need to remove the brake cable from inside the car or can i do it right from the caliper on my 88 vette
Old Dec 10, 2005 | 01:43 PM
bogus's Avatar
bogus
the cable should come off at the caliper. the mechanics, if I remember rightly, are part of the bracket, not so much the caliper.
It's been a while since I messed with them.
Old Dec 10, 2005 | 07:13 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I have done this several times and there is no need to remove cables or tubing from caliper. It will move out of the way just fine..at least on my 88
good luck
jack
Old Dec 11, 2005 | 01:08 AM
Sidney004's Avatar
Sidney004
No need to remove the parking brake cable from inside the car. Just remove the spring on the caliper with vice grips and you are on your way.
Sidney
To rear caliper
