CCM harness removal
Old Dec 11, 2005 | 02:53 PM
4cefed's Avatar
4cefed
Default CCM harness removal
I finally had time to get back in the garage to finish fixing the CCM problem I had. All I had to do was remove the two harness connectors and remove the CCM.
Can someone give me the secret in getting the right harness off? I got the left one off with some work but it seems I need three hands down there to hold the lock tabs out of the way and pull down on the connector while holding the CCM. Gettign to the buried thing wasn't nearly as bad as trying to get these darn connectors off.
Has anyone done this lately? Should I go in on the passenger side and remove the bracket and get to it from that side as well?
I just want to make sure I don't damage the connectors. They seems fragile enough as it is.
Old Dec 13, 2005 | 07:07 PM
corvette1989bham's Avatar
corvette1989bham
It has locking slide pins like the airbag connectors. The harness can be plugged up backwards..be careful.
