To swap or not ??
Old Dec 11, 2005 | 08:45 PM
rssshen vette's Avatar
rssshen vette
Default To swap or not ??
I have a 85 L98 with a newly installed 383. The plenum, runners, distributor and tranny are the only stock items left. I want to swap the rear gears (currently Dana 36 2.73's) to a 3.54 or 3.73.
My question is Should I swap the dana 36 to a 44. or shuold I keep the dana 36 and up grade the gear ratio? I do take the car to the local track on the weekends. And I do take loooong cruises. So what would be the best route ?
Old Dec 11, 2005 | 08:47 PM
Pete K's Avatar
Pete K
Buy the 44. Cheaper in the long haul.
Old Dec 11, 2005 | 09:38 PM
rssshen vette
will I have to swap the entire rear end or can I just swap the center unit.
Old Dec 11, 2005 | 09:49 PM
hippy's Avatar
hippy
The whole unit, C beam and driveshaft.
Old Dec 11, 2005 | 10:30 PM
85vet's Avatar
85vet
Cruise-In V Veteran
The 36 is on borrowed time - Go for the 44
Old Dec 11, 2005 | 11:05 PM
aboatguy's Avatar
aboatguy
D44s are not the end all however, they hold up better than a D36.
Since you have modded your engine you may as well mod the driveline to take the additional torque!
Old Dec 12, 2005 | 08:22 AM
Gary K's Avatar
Gary K
D44 unless you don't plan to run it hard...which I think is not the case since you have a 383.
Old Dec 12, 2005 | 05:05 PM
CFI-EFI's Avatar
CFI-EFI
The center section with the batwing at the minimum. The drive shaft MAY be necessary and a new "C" beam will save you drilling your old beam. Nothing from the 1/2 shaft yokes, outward is any different.
If you have the resources to buy the 44, you will be money ahead. If you keep building and racing, the 36 will fail eventually and THEN you'll be looking for a 44. However, there are stories of some 36s taking some incredible abuse and surviving.
RACE ON!!!
To To swap or not ??
