Lowering question
Old Dec 12, 2005 | 05:56 AM
devilfish's Avatar
devilfish
Default Lowering question
The pre-owner of my car has installed some kind of lowering kit. I always thougt it whas to low and when I compare the ride hight of my firends C4ors ( that used lowering kits from ecklers etc ) my car is around 1 inch lower then theirs. So I thougt my shocks where out. But when I change my shocks to brand new ones the ride hight did not change.
What can the pre-owner have done to lower the car even more then what the kits allow? Can the springs be "out" ? There is nothing wrong in how the car handels, its just that its a bit to low for me :/
Old Dec 12, 2005 | 06:58 AM
Casethecorvetteman's Avatar
Casethecorvetteman
For the front, just jack the spring up at each end and put some packing under it, until you have the desired ride height. For the rear, just install shorter bolts that hold the outer ends of the springs.
Old Dec 12, 2005 | 08:08 AM
aboatguy's Avatar
aboatguy
The previous owner may have cut some of the rubber off of the pads on the spring ends. Case's suggestion will raise the car.
But why?
Old Dec 12, 2005 | 11:51 AM
js292's Avatar
js292
Yeah, I just bought an 85 with the same prob. It sits so low it is rubbing on the underside of the hood. To bad it rubs cause it looks good
Old Dec 12, 2005 | 12:07 PM
devilfish's Avatar
devilfish
Got the exact same probleme
Good advice on put some packing under it. Thanks guys..
Old Dec 12, 2005 | 02:05 PM
aboatguy's Avatar
aboatguy
OK, if its rubbing it's too low!
Old Dec 13, 2005 | 12:26 AM
devilfish's Avatar
devilfish
What kind of material should I as packing? Any tips?
Old Dec 13, 2005 | 12:43 AM
Casethecorvetteman
Neoprene.... As long as its not too hard that it will wear at the lower control arms, but hard enough that the spring wont eat it away...
Old Dec 13, 2005 | 03:13 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The rear can be raised simply by tightening the the nuts under the spring end on both sides. The aftermarket kits come with longer bolts and nuts with nylon inserts (nylock). Whether you've got factory castle nuts or nylocks, I'd put two on each spring bolt as jam nuts.
To Lowering question
