ZF-6 into 85
Old Dec 13, 2005 | 07:32 PM
ZAWA's Avatar
ZAWA
Default ZF-6 into 85
I have a 95-96 ZF-6 trans, bellhousing from chevy crate motor, cultch master and slave and hose from 93. Can I use the stock clutch or do I need different parts? Your input is most welcome.
Old Dec 13, 2005 | 08:47 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The stock clutch can't be used because there's no room for a throwout bearing or slave+fork to disengage it.
You need ZF6 clutch hydraulics, clutch set, and bellhousing.
Old Dec 13, 2005 | 09:56 PM
ZAWA's Avatar
ZAWA
My next ? Can I use a ZF-6 clutch with the 85 flywheel? If not would my options be?
Thanks again for any help.
Old Dec 13, 2005 | 09:59 PM
CentralCoaster
Yes you can. The zf clutch and pressureplate surfaces are actually bigger diameter than the 85 FW, but bolt up fine.
Old Dec 14, 2005 | 08:38 AM
ZAWA's Avatar
ZAWA
Again thanks, Which clutch should I use 89-93 or 94-96, the trans is a 95-96 unit? In some of your earlier posts you mention spacers what are these? My car is stuck on my frends lift so trying to get all the parts together as fast as possible.
Old Dec 14, 2005 | 10:41 AM
CentralCoaster
I used all 89 parts except the bellhousing and starter and it works great. Perfect clutch engagement.
Go here for application chart:
http://webpages.charter.net/khasting...fo/zfswap.html
Old Dec 14, 2005 | 04:30 PM
ZAWA's Avatar
ZAWA
That should help alot, just have to wait for bellhousing to get here.
To ZF-6 into 85
