Help with front Caliper pin???
Old Dec 14, 2005 | 02:34 AM
99SoCalFRC's Avatar
99SoCalFRC
Default Help with front Caliper pin???
OK guys if you remember from yesterday we had a car towed (C4 91) because the left front was locking up. I got the tire and such off, it appears the pin that holds the caliper in at the bottom was lost? this caused a catastrophic failure and the locking wheel. So moving on do I just buy a new pin? How does it fit in there? I tried to look off the other side but only have the one wheel off, I have bought new pads already, just need advice maybe on how this front assembly should go back toghether.
I have done brakes before just always ones that bolted to the caliper bracket this whole pin thing is new to me, any help is appreciated as always!
Old Dec 14, 2005 | 09:03 AM
bogus's Avatar
bogus
wow. I would make damned sure the caliper and wheel weren't damaged too severely.
you will also need to check the bracket to make sure it wasn't bent or damaged in some way.
you will need a pin, washer and e-clip.
Old Dec 14, 2005 | 09:11 AM
LTjuan's Avatar
LTjuan
I am with Bogus, I would check and make sure nothing is bent. As far as install you just line up the holes and the pin slides thru, and you lock it in place with the clip. I assume thats what was missing on your car. It was designed to be very easy and quick. It takes longer to get the wheels off than it does to replace the pads.
Old Dec 14, 2005 | 11:23 AM
CFI-EFI's Avatar
CFI-EFI
I don't have reference material for a 1991, but when I had a similar problem, it was the bolt (there are 2, an upper and a lower) that bolts the caliper bracket to the knuckle that fell out. The caliper pivoted on the remaining bolt and wedged itself into the I.D. of the wheel, and locked it up. All that had to be done, was to swing the caliper back into position and replace the bolt (with Loc-tite applied) and tighten (with Loc-tite) the other bolt.
RACE ON!!!
Old Dec 14, 2005 | 11:26 AM
99SoCalFRC's Avatar
99SoCalFRC
CFI has it right on this is how the wheel locked, the brackets are still solid, but the caliper swumng out and caugt on the inner wheel to lock it up, mostly only chewed up the fins on top a little bit.
Old Dec 14, 2005 | 11:57 AM
CFI-EFI's Avatar
CFI-EFI
I was over 800 miles from home on my way to the 2000 NHRA Division 7 Bracket finals at the then Sears Point Raceway (Infineon, today) when my right front wheel locked up at the bottom of the Interstate ramp at Vallejo, California. I backed up and got the wheel unlocked and headed for the nearest repair shop. To make an interesting story short, they replaced the bolt and sent me on my way. A couple of days later, I won my first Wally.
RACE ON!!!
Old Dec 14, 2005 | 01:58 PM
chaos on wheels's Avatar
chaos on wheels
Here's a pic of the caliper on the bracket. Pin w/ e-clip is on the right. Arrow points to the anti-rattle spring for the brake pad.
Old Dec 14, 2005 | 03:11 PM
99SoCalFRC's Avatar
99SoCalFRC
Thats great do you have any other pics of that assembly?
Old Dec 14, 2005 | 04:51 PM
99SoCalFRC's Avatar
99SoCalFRC
Well guys looks like I will have to get a whole new caliper assembly as the pin is not availiable by itself.
Old Dec 14, 2005 | 05:16 PM
96GS#007's Avatar
96GS#007
Someone is feeding you a HUGE line of I just bought pins and clips from Chris May at Superior Chevrolet. Cost was something like $10
Old Dec 14, 2005 | 05:34 PM
CF6873's Avatar
CF6873
The pins are a separate part # and so are the clips. try another GM dealer. They are available.
Old Dec 14, 2005 | 06:35 PM
99SoCalFRC's Avatar
99SoCalFRC
Anyone have the part numbers for said pins and clips? I would really appreciate it!
Old Dec 14, 2005 | 06:59 PM
99SoCalFRC's Avatar
99SoCalFRC
How about the number to this superior chevrolet?
CFI-EFI's Avatar
CFI-EFI
Thought I HAD it.
On my car is was plain hardware; a metric bolt, M12 X 1.75 X 40. My 1984 to 1990 parts book only shows the part number, not the dimensions on the 1985 to 1990 cars. It shows the pins and clips, too, but of course nothing for the 1991.
RACE ON!!!
Old Dec 14, 2005 | 09:38 PM
96GS#007's Avatar
96GS#007
1-800-728-8267 (ask for Chris May)
http://www.superchevyperformance.com/
The p/n's shown below are for the J55 brakes (13" rotor). If you have the base set up (12" rotor), it likely uses a different p/n pin.
10140666 Brake Pad Pin
10132842 Brake Pad Pin Retainer
Old Dec 14, 2005 | 09:57 PM
bogus's Avatar
bogus
Originally Posted by CFI-EFI
Thought I HAD it.On my car is was plain hardware; a metric bolt, M12 X 1.75 X 40. My 1984 to 1990 parts book only shows the part number, not the dimensions on the 1985 to 1990 cars. It shows the pins and clips, too, but of course nothing for the 1991.
RACE ON!!!
the 1988 to 1996 front brakes were all interchangeable. So whatever dimensions exist for 1990 would apply.
Old Dec 15, 2005 | 12:50 AM
chaos on wheels
More pics of my grungy brakes:
E-clip is on the bottom.
Remove E-clip, pull pin, and caliper pivots out of the bracket...
To Help with front Caliper pin???
Old Dec 15, 2005 | 01:12 AM
99SoCalFRC's Avatar
99SoCalFRC
Great great stuff guys, I did the other side tonight so I got a good idea of how it is SUPPOSED to work as opposed to the let's say incomplete side, I will try to tackle the pin search tommorrow, does it matter which direction the pin is put in? I just noticed it is a bit hard to get the e clip out with it being on the inside, though after swapping the pads I put it back the way I found it!
Old Dec 15, 2005 | 04:06 PM
99SoCalFRC's Avatar
99SoCalFRC
Called superior what incredible service, they actually took the time to find the part number instead of feeding me the bs about an all new caliper, They gave me the p/n and I went to the local dealer, you can imagine their surprise when they saw these pieces actually existed HAHA.
Old Dec 16, 2005 | 08:55 AM
larryfs's Avatar
larryfs
autozone carries a brake hardware kit, and it may include the pins. I know I needed the anti rattle clips, and I think the pins were included too.
I buy a lot of stuff from Superior chevy. I manage a fleet of 5 GM cars. always good service.
