LED question
Old Dec 15, 2005 | 11:07 AM
jburnett's Avatar
jburnett
Default LED question
I'm involved in changing a dash out on a car right now and I'm looking for some small (like 1/4" or smaller) 12 volt LED's... I can't find any anywhere, I've got some from Radio Shack that are 1.5v but I'd have to use a big resistor to go down to it. The LED's will be for the turn-indicators, bright light indicator, and the CES light... Anybody have any ideas or suggestions?
-Jeb
Old Dec 15, 2005 | 11:26 AM
grandspt's Avatar
grandspt
Try Digikey electronics. www.digikey.com or 1-800-344-4539
They may have what you need.
Old Dec 15, 2005 | 11:35 AM
SJW's Avatar
SJW
Agreed, DigiKey will likely have what you need. If not, try Mouser, Allied and Newark. What you probably want is an LED that has a built-in dropping resistor (to limit the current) and is intended for use across a 12 volt circuit.
Alternatively, you can select any LED you like, and add your own dropping resistor to configure the LED to live happily across 12 volts. LEDs need a resistor (in series with them) to limit the current through them, or they'll not live long.
Be well,
SJW
Old Dec 15, 2005 | 02:56 PM
bill mcdonald's Avatar
bill mcdonald
I purchased some from the net somwhere, for something like 100 for 20 bucks. they came with resistors. they were pretty small. I have done some work to a few other cars to change the dash colors out.
I am stepping out to lunhc right now, but I hope to return with a link. maybe some pics.
Old Dec 15, 2005 | 03:02 PM
bill mcdonald
http://www.modsthatglow.com/White_10k.htm
these come with the resistor needed to kick the 12 volts down so you dont blow the LED. the resistor is a lot smaller then the led and works well.
here is a celica dash I did some work on.
this was originally all orange and looked kinds gross with the green stereo etc.
here is a pic of the resistor taken from a Z06 web page.
http://www.spdkilz.com/techtip.html
here are some tech tips on how to do these mods on a Z06.
I dont know how much help they will be, but you get the idea
To LED question
