Question on fuel problem
Old Dec 15, 2005 | 01:13 PM
smilen_31's Avatar
smilen_31
6th Gear
Default Question on fuel problem
I have an 86 C4 that will start when cold but dies after 10 too 15 minutes of ideling and will not start until it cools off again. I have changed the ignition module and the coil. I do get spark after ir dies but it seems it is missing fuel. Has anyone ran into this problem?
Old Dec 15, 2005 | 02:06 PM
CFI-EFI's Avatar
CFI-EFI
Based on what you have written, I would connect a fuel pressure gauge and monitor the described events and the attending fuel pressures through out those events. If that doesn't tell you what is wrong, post your observations. Maybe with some input, someone, here, can help you.
RACE ON!!!
