air pump 85
Old Dec 16, 2005 | 11:54 PM
vtwin's Avatar
vtwin
4th Gear
Default air pump 85
Hi there i have an 85 and im thinking of removing the air pump system will this have any effect .
Im running a stage 2 chip and im adding a matched cam. Aussie vette
Old Dec 16, 2005 | 11:59 PM
bogus's Avatar
bogus
the only thing that might stop you is emissions laws... otherwise, remove it and it's plumbing. There are kits that will replace the pump with an idler pulley.
Old Dec 17, 2005 | 08:54 PM
vtwin's Avatar
vtwin
4th Gear
By removing the pump system will this cause the computer to post a fault code . thanks for you're reply. Aussie Vette
Old Dec 17, 2005 | 08:58 PM
vader86's Avatar
vader86
No codes on L98s from removing AIR.
No problem passing a sniffer, provided the engine is warmed up.
Old Dec 18, 2005 | 12:24 AM
goldeneye_vet's Avatar
goldeneye_vet
Remove it! The front piping on mine along the front of the block was all rusted out. Put an air pump eliminator kit on and have been plenty happy. Much easier to work on now as well. Look at Agent86's setup. He had the template on line for a while. I'd love to build what he did.
To air pump 85
