Power steering pump wine
Old Dec 17, 2005 | 08:52 AM
96lt4c4's Avatar
96lt4c4
Default Power steering pump wine
I decided to drive the car to work this morning. It has been sitting for about a month.
It was really cold around 28 degrees this morning when I fired it up. Instantly I heard this loud wining sound coming from the power stearing pump. I shut the car off and checked the fluid and it was full. I started the car again and this time I turned the wheel a few times and it got louder, I also started to smell rubber burning like the belt was slipping. I let it run a little until it warmed up, and the noise finally went away. Anybody ever have any problems with the PS pump or have to change one? My guess is the car may have had one put on in the past and they didn’t prime the pump like they were suppose to.
96 LT4
46,000 miles
Old Dec 17, 2005 | 09:27 AM
mseven's Avatar
mseven
What does the fluid look like now? If it is burnt looking and smells the same changing the fluid it might help. I would try this first before swapping out the pump.
Old Dec 17, 2005 | 10:56 AM
96_LT4_FE1's Avatar
96_LT4_FE1
Change the fluid, then try again. To change my fluid I put a short length of hose on the return at the tank, and pointed it up so the tank couldn't drain. I then routed the return from the rack to a drain pail. With the car on jack stands, wheels in air, you turn the wheel back and forth(slow, smooth, lock to lock), engine off, and it pumps the old fluid out. If you keep the reservoir topped off, you just keep going till fresh fluid is coming out. kinda just like brakes.
On the plus side, if the pump is bad, they are normally inexpensive and easy to change. I changed one on my LT1 f-body, but it turned out it wasn't bad in the first place, still, it helped me track down the problem and it was cheap troubleshooting. If you do change it, the one special tool you must rent(usually its free at autozone, just pay a deposit) is the power steering pulley puller. Other than that, its pretty straightforward.
HTH, »keith
Old Dec 17, 2005 | 11:34 AM
vettl83's Avatar
vettl83
I would recommend changing to synthetic power steering fluid. When the temp. drops to 0 degrees around here all the power steering units seem to moan and groan for about 30 seconds, even on brand new vehicles "Fords seem to be the worst." The synthetic fluid seems to cure the problem assuming the unit is in good mechanical shape to begin with. 91 ZR1 #2039
Old Dec 17, 2005 | 11:59 AM
96lt4c4's Avatar
96lt4c4
Sounds good where can you get the synthetic fluid? Auto Dump.....I mean Zone.
Old Dec 17, 2005 | 12:06 PM
vettl83's Avatar
vettl83
Get in touch with Red Line Oil at www.redlineoil.com if they don't have a dealership in your neck of the woods they will ship to you direct. 91 ZR1 #2039
Old Dec 17, 2005 | 12:15 PM
CFI-EFI's Avatar
CFI-EFI
Easier and quicker, is to disconnect the large pink wire from the "Bat" terminal at the distributor cap, so the engine won't start, and crank the engine with the starter.
RACE ON!!!
Old Dec 17, 2005 | 01:02 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I use synthetic fluid and have the same problem. Really cold or really hot fluid and it whines. PS cooler didn't seem to help any.
I'm gonna try a new pump.
Old Feb 17, 2006 | 10:19 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Change the fluid and replace with Lucas Power Steering Stop Leak and Conditioner. That'll blunt C4 morning sickness every time.
Old Feb 17, 2006 | 10:24 AM
Lichen's Avatar
Lichen
You or another forum member suggested that a few weeks ago. I put some in and it helped a lot.
Old Feb 17, 2006 | 11:29 AM
onedef92's Avatar
onedef92
Worked for me, too. Dat's how I 'splain it!!
Old Feb 17, 2006 | 01:59 PM
Slalom4me's Avatar
Slalom4me
Member 'superlund' mentioned GM's "Cold Climate" fluid (PN 12345867)
once when posting about a different topic over in Autocross & Racing.
28ºF is not cold for some folks. Neighbors to the east of me are coping
with temps dipping to -49ºF today.
Pump noise on startup is not something to be alarmed at in these parts,
certainly not a sign of impending pump failure in my books. The whine
is a familiar sound on cold days here and I do not know of ANY instance
of average folks having to change out a pump over the lifetime of a
vehicle. C4's tend to be parked here in the winter but the same pump
was/is used in other, more pedestrian GM products.
Changing the fluid wouldn't hurt. The racers seem to use the Cold
Climate fluid under hot, extreme conditions so I suppose you could
leave it in year round. Further investigation could give you more
opinions/information about that aspect.
Old Feb 18, 2006 | 08:21 AM
No Go's Avatar
No Go
Another possibility is a frozen pulley.
My car sat over the winter and when I started it I had the idler pulley freeze with the serpentine belt rub over the plastic surface. It rubbed to the point the pulley got a flat spot on it.
I didn't notice it right off as the pulley eventually 'broke free' and rotated...but it was funny to see-'heh that pulley looks odd!'
To Power steering pump wine
