What is the best way to eliminate or alleviate front end skitter? Basically when I drive down the highway, I get a lot of jumping from the front end when I hit a bump or crack. I no it's due to the tight suspension, but is there anything that can be done to improve performance.
What's the condition of your:
alignment
shocks
suspension bushings
tire condition
tire pressure
GM attempted to alleviate this condition by putting smaller tires on the front, in the later years of C4 production.
On my 92 lt1 replacing the shocks with used shocks purchased here solved the problem. My old shocks had 153,000 mi. on them. The replacements had 40,000 on them. They seem to last forever .
My 95 with base suspension had the same problem (I bought it in 12/95 with 2300 miles). I replaced the stock Bilsteins with adjustable Konis and virtually eliminated the problem. Bilsteins are generally decent shocks, but IMO, the GM spec valving was designed to make the car ride like an old Caddy.
alignment
shocks
suspension bushings
tire condition
tire pressure
Mike
Something isnt right in one of the ubove things there .
with the KONI adjustables, i have them and havent ever noticed anything other than bad wandering when i first got the car, was worn bushes and ball joints. Im not so sure about the old Caddy coment though!!!
