Running Temperature creep....
Old Dec 19, 2005 | 04:24 PM
ceberus's Avatar
ceberus
Default Running Temperature creep....
The running temp of my C4 used to be 193F. Over several years, the termperature has creeped up to where it now runs at 207F. I have flushed the system and replaced water pump (when I did the distributor). I have changed the thermostat to a 180, and it ran 7F cooler at 200F.
Common sense tells me this is the temperature sending unit on the water pump, but at the same time this seems to simple. Maybe I need a new radiator? Before I drain the fluid and replace the temp sending unit, I thought I would ask if anyone has encountered a similar problem and if this is normal? Recommendations?
Old Dec 19, 2005 | 04:33 PM
ittlfly's Avatar
ittlfly
You didn't mention if you cleaned out the area between the radiator and condensor? That area seems to trap a lot of debris.
Old Dec 19, 2005 | 04:37 PM
ceberus's Avatar
ceberus
Yeah, that is a very difficult area to clean, but I did spray that area very well with a hose. Several years ago a plastic shopping bag got sucked up into that gap, and it caused my car to overheat.
Old Dec 19, 2005 | 04:49 PM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by ceberus
The running temp of my C4 used to be 193F. Over several years, the termperature has creeped up to where it now runs at 207F...
What problem? Certainly not running at 207°, I hope?
Since you changed the water pump when you changed the distributor, and you have a temp sending unit in your water pump, I have to guess that you probably have a GEN II engine. The 180° thermostat is stock in the C4s with, LTx engines.
RACE ON!!!
Old Dec 19, 2005 | 05:02 PM
ceberus's Avatar
ceberus
"The 180° thermostat is stock in the C4s with, LTx engines."
Really? I bought my car brand new in 1992, and I remember it always ran at 193F? It now runs at 207F with the original thermostat.
Old Dec 19, 2005 | 07:01 PM
CFI-EFI's Avatar
CFI-EFI
And your point IS???
RACE ON!!!
Old Dec 19, 2005 | 07:16 PM
okies93's Avatar
okies93
St. Jude Donor 06
Pull the radiator and be done with it. Garden hose while it is in place won't cut it...
Old Dec 19, 2005 | 07:42 PM
CFI-EFI's Avatar
CFI-EFI
RACE ON!!!
Old Dec 19, 2005 | 07:55 PM
Lichen's Avatar
Lichen
RACE ON!!!
Most people would be tickled pink with those low temps. 207* is what, half-way on your analog gauge?
Old Dec 19, 2005 | 08:15 PM
jabez's Avatar
jabez
I see nothing wrong with running at 207 degrees.
Kinda crazy to think you need a new radiator.
Old Dec 19, 2005 | 08:33 PM
ittlfly's Avatar
ittlfly
Yep.
Old Dec 20, 2005 | 09:33 AM
rick lambert's Avatar
rick lambert
me too
Old Dec 20, 2005 | 11:43 AM
LT4BUD's Avatar
LT4BUD
On an LT engine an indicated 193 would be pretty normal for a 180 stat when running down the highway. 207 is certainly in the normal ok range to be running.......the new stat should have restored it back to normal.....since it didn't I agree with others that you need to carefully clean the radiator....anyhow changes always stimulate interest as to why....
What seems to have changed with mine is that when new there was either no or maybe 1-2 degrees increase in temp when running the A/C in summer.....now it seems to increase the temp by as much as 4-5 degrees...
Old Dec 20, 2005 | 01:40 PM
CFI-EFI's Avatar
CFI-EFI
It must be time for a new radiator, a new condenser, a new evaporator, change the oil in the compressor, change the air in the tires and rotate the radio *****.
RACE ON!!!
Old Dec 20, 2005 | 01:48 PM
LT4BUD's Avatar
LT4BUD
RACE ON!!!
I forgot all about the radio *****....with my exhaust the radio hasn't been on in years......I think this might be it
BTW 193 was the norm on my LT4 when new......after doing the unthinkable of running a 160 stat my norm changed to 173......
To Running Temperature creep....
