I drove over to my friends shop last night and the machanical gauge confirmed the oil pressure was fine. I changed the oil with Royal purple 10/40 and it brought it down about 8 psi. Running down the road I have 60 psi and 38 @ idle. What a deal!!!!
I got to drive her on my first twisty country road on the way to the shop. WHAT A BLAST!
Walker
I thought you were fine-but it's always comforting to know for certain.
As a side note; I just read some of the latter responses to "high Pressure " , some of us old timmers can remember when we had to do the stiffer spring thing ourselves-and that is the basic issue between a stock pump and a high pressure pump. You can't increase volumn with the stock pump-but you can increase pressure-as the saying goes "the proof is in the pudding" -not to start any kind of flame-but messing with motors for-lets see, 48+ years I've done the oil pump thing several times with the same out come-higher oil pump pressure. Now there does come a time when bearings become so shot it won't really do a thing-but on an engine with good bearings-it does. BTW-my father was a Hydraulics engineer.
Walker
I do not trust a single electronic gage in ANY car. Mechanical is the ONLY way to go. Suggestions for even mechanical gages. You should use large diameter hose, not the itty bitty stuff they give you with the gages, especially the plastic stuff, because by the time the small stuff reacts to the pressure change the motor is seeing, its too late sometimes. Run good diameter hose, braided preferrably and you will have near instant reaction time from your mechanical gages.
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Since motor oil is a non-compressible, the small diameter oil lines will not affect your pressures or changes in pressure. That's the beauty of hydraulics.
Small diameter lines WILL affect flow, but there is no flow in an oil pressure gauge line.
Larry
code5coupe
Guess I should have been more precise in what I was trying to convey when I alluded to the plastic type lines supplied in many mechanical gage. These line will bend, and perminently may keep pressure built up and delay the effects of the pressure change. Had it happen, on shutdown of the motor, the pressure would slowly bleed off.
Most of the madeup braided lines have a larger id hole also.
There is no question that the oil pressure from a high pressure pump will be greater than from a standard pump, but only beyond the point at which the relief valve opened on the stock pump.
My father was a thoracic surgeon, but I don't think you want ME doing your open heart surgery. What size wrench do I need for that artery?
first time I think I've caught a sense of humor from you CFI-EFI,
getting tutored on basic hydraulics is not close to heart surgery
and absolutely no way you'd get a chance at my heart-wrench? try a c clamp and a exacto kinife lol. Have a great Christmas and "Race on"
