Rusted frame on early c4???
My main question is if vettes have a tendency to get rusted out from underneath (obviously not the body) in a snow-ridden city. Afterall, even if the owner doesn't "drive" it in the winter, it could still have seen salt and have a rusted frame. I doubt i'd want to get into pricing for a local shop to replace the frame or repair segments...
The frames are made of steel / low alloy and I've never heard of one rusting out. I'm on my second C4 (1989 & 1986) and the frames have always looked like new.
Having driven the 89 occasionally in the winter, you'll soon find that they are absolutely terrible in the snow and you'll soon try to avoid it at all costs, which should greatly diminish the ill effects of salt.
A cursory visual of the frame should tell you what shape it is in. The first thing I would do when searching for a used Vette is to look for a low mileage example.....my last one was owned by an old guy and only had 24,000 miles and looked like new. Try to find one where the service records are available and for goodness sake get a mechanic to give it a once over before you buy. Don't buy it alone, bring a knowledgable buddy and take your time. It's easy to get excited and miss a few important steps.
Try the AutoTrader website in both Canada and the US and look for that low mileage creampuff; they're out there
Good Luck !
Ken - Windsor, Ontario
Buying long distance, sight unseen, and relying on the honesty of the seller is risky. You might be able to get a forum member near the Vette you are interested in and ask that they inspect it for you. If you're looking for a guarantee I doubt you'll find one. You might have more peace of mind buying one in Canada where you can inspect it personally. Check the classified on this forum, there might be something there that meets your expectations and may be know by other members who can vouch for it's condition.
I have to agree. These C4's are nothing like the C3's with rusted bird cages et al. Driving a vette in the snow, although very doable, is a suicide mission that few undertake. We have a few members that drive year round, but like most of us they are fanatics and keep everything nice with religious cleaning. I would bet a nut that you would be extremely hard pressed to find a C4 with a rusted frame, the parts you can see anyway.
Someone will correct me if I am wrong but my understanding of the following is slim. The C4 looks like a unibody, but it isn't. The frame is integral to the car, and you would have to literally cut the car from the frame to be able to see it. The parts you can see might be scaley with paint flaking off in spots, but it's nothing to worry about.
I have a cavalier, a 97 owned since new and driven year round, that mechanics actually compliment me on because the underside is cherry. I am at the car wash once a week in the winter time and take good care of it though. My point is, don't worry about the structural integrity of the frame unless you have some reason to believe the car was in an accident. Given most of us drive different cars in the snow, and usually wait until the first good rain to wash the salt off the roads before we drive, you'll be fine.
But you really need to inspect way up inside there for any possible problems.A quick look under isnt wall it takes.
That being said,the fuel lines,gas tank,sway bar and etc easily get rust on them.I replaced the gas tank and fuel lines in my 86 because of rust.
The back fuel lines were so corroded with rust,they were inside above the wheel well frame area,I was wondering when the next bump would bust a hole in the lines.These are the critical areas to inspecting any and early C4's to see what its going to cost you IF those areas need repairs.
The car had been through some snowstorms in the NE area and the road salt was the probably the main cause.
This subject has been covered in depth elsewhere..). keeping an eye underneath for the effects of salt shows that it is starting to take a toll - the brake and fuel lines in the back are beginning to get rusty (time to oil it up - it isn't a show car, after all). Maybe I'll replace with stainless lines when the time comes and eliminate the issue. I'm somewhat more concerned about the aluminum rear subframe - it's showing a surface oxidation, at least I Hope it's just a surface oxidation, that doesn't look healthy. I haven't found a good way to stop/prevent it - yet - either. The aluminum Suspension pieces, incl. the diff, all seem to be immune. The radio antenna looks very exposed - but so far it's holding up OK. The parking brakes ('85 is internal expanding drum type) seem well protected and are also holding up well. Other areas to watch: The floors under the seats are sheet metal - and will also rust from the Inside (under the carpet). The metal guards at the leading edges of the footwells should be protected - I undercoat over them. The gas tank wouldn't leak even if the metal skin did rust through - the plastic bladder would still be intact. Since gas tanks normally rust through from the Inside (water in the fuel) anyhow this probably isn't ever going to be a problem on a C4. The Exhaust is what it is - probably the most suseptable stuff under there.With the possible exception of the rear aluminum sub frame the rest of the "structural" stuff - the main frame itself, looks Really good - not even showing any Surface rust except for the cross bulkhead behind the seats - right at the bottom where it's the most exposed - and not Bad even there - a little paint in the spring will solve That problem. It appears that the car will survive it - and continue to get used (snow, salt or whatever) for many more winters to come... Use it - it's what it's for!
I have an 88 4+3 that will be for sale, Actually it can be for sale right now! Car has 121k or 75000 miles on it. NO RUST! Car has been taking care of........If your serious and want a clean car let me know. I am just north of T.O. up in Barrie. I too was going to do a 383, So if I sell the car, I have alot of performance parts that I will have to unload like a brand new set of TRICKFLOW HEADS, and a MINIRAM II intake system with fuel rails. You can pm me for further info. I have pics, and vids of my car. No shortcuts!
.............The windshield frame is also prone to rust.This is the windshield frame in my 84.Ive had this car since 87 and as far as I can tell the windshield has
never been replaced until now,and I live in Ca.
