Bigger Cam / Idle question...
Old Dec 22, 2005 | 03:40 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
Default Bigger Cam / Idle question...
For those who run bigger cams - what do you have your "target" or "desired" idle RPM programmed to?
I'm running a .580 lift / 240 @ .050 duration cam (112 + 4, 16* overlap) in my 383. Target idle is currently programmed at 850 rpm, but it seems low to me. Just curious where others are at.
Thanks!
Dan
Old Dec 22, 2005 | 04:06 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Thanks!
Dan
900 to 950 seems to work well. Keeps the oil pressure up a little also and smooths out the idle.
Old Dec 22, 2005 | 04:31 PM
Zix's Avatar
Zix
I have my idle set at 975 and it runs very smooth and doesn't sound high, my cam specs are
242/252 duration @.050 .55x/.56x lift 110 LSA
Old Dec 22, 2005 | 05:18 PM
byebyeL98's Avatar
byebyeL98
Thanks Ski / Zix - I was thinking along those lines as well, for just the reasons you listed. It idles just a little bit too rough at 850 rpm.
Old Dec 22, 2005 | 06:29 PM
hippy's Avatar
hippy
If this helps I am running a 219 at 850.
Old Dec 22, 2005 | 06:39 PM
CFI-EFI's Avatar
CFI-EFI
Thanks!
Dan
Exactly what do you mean by this? I do not believe you if you are saying you have 16° of overlap. And I really don't think you are. But what ARE you saying?
RACE ON!!!
Old Dec 22, 2005 | 06:45 PM
hippy's Avatar
hippy
RACE ON!!!
My guess is you already know what he is trying to say. And that is that he is adding numbers that aren't addable. Am I correct in MY assuming this?
Old Dec 22, 2005 | 07:03 PM
CFI-EFI's Avatar
CFI-EFI
No, You are not correct. I truly have no idea what he is saying, there. Would you care to speculate?
RACE ON!!!
Old Dec 22, 2005 | 07:26 PM
86VX1's Avatar
86VX1
have you tried asking the people that sold you the grind?
Old Dec 22, 2005 | 07:48 PM
mseven's Avatar
mseven
Looks like he is posting lobe centerline of 112* and +4* advance cam timing ????
Old Dec 22, 2005 | 07:49 PM
byebyeL98's Avatar
byebyeL98
Sorry if I gave the wrong information. What I was trying to say (and obviously did not do so correctly), was that the cam has a 112* lobe separation angle with 4* advance built in.
Based on CFI's comment, I may have miscalculated the overlap figure from my cam card. :o All figures were hand written on the card, so I'll need to check with the manufacturer for the specs (Howard's Cams), and I'll ask them for a target idle while I'm at it.
Thanks!
Old Dec 22, 2005 | 07:58 PM
CFI-EFI's Avatar
CFI-EFI
Nobody has sold ME anything.
I'm good up until, "(112 + 4, 16* overlap)". Then I ASSUME "112" is the lobe center displacement angle? Does "+4" mean that the cam was advanced 4°? Was that 4° ground in at manufacture? Or added during installation? OR both? I would prefer to not even speculate on "16*". How about it, 86VX1, what's it all mean?
RACE ON!!!
Old Dec 22, 2005 | 08:08 PM
Zix's Avatar
Zix
RACE ON!!!
Okay, now you're confusing me!
86VX1 didn't start the thread he just wanted to know if ByeByeL98 asked the cam manufacturer about it
ByeByeL98 started the thread...you should be asking him what it all means.
Old Dec 22, 2005 | 08:13 PM
byebyeL98's Avatar
byebyeL98
See my previous post
(and I now FULLY understand the ramifications of NOT posting clearly )
Old Dec 22, 2005 | 08:47 PM
CFI-EFI's Avatar
CFI-EFI
ByeByeL98 didn't have any questions about the cam grind, only a statement, which caused ME to have questions. With no pronouns, his post followed mine. Therefore, I am ***-YOU-ME ing that 86VX1 was talking to me. Maybe not.
ByeByeL98,
Now that you explain what you were doing, your arithmetic is probably correct..., for the overlap at .050" lift. However, gases start flowing LONG before the valves get to .050" lift, and makes that a meaningless number. If that is what you did, that 16° number, is as meaningful as if it were expressed in furlongs per fortnight. If you re-figure from the "advertised" event points. you will come up with a worthwhile number.
Also, for the record, I was called to the front door and although I posted after the number 10 and 11 posts, I hadn't seen them until after I posted.
RACE ON!!!
Old Dec 22, 2005 | 11:00 PM
hippy's Avatar
hippy
RACE ON!!!
Yea we're pretty close on the unaddable math. I won't guess either but these are the numbers that I expected what they meant. 112, put in 4*(doesn't matter witch way) but you can't add it to 116.
CFI- you actually have enough knowledege in your melon to help people out. You can read the errors as much as I can, so just help them out.
Am I wrong or not?
Old Dec 23, 2005 | 12:34 AM
Dominic Sorresso's Avatar
Dominic Sorresso
Overlap is based on the .006" lift numbers. What are they for this cam?
To Bigger Cam / Idle question...
Old Dec 23, 2005 | 02:34 PM
CFI-EFI's Avatar
CFI-EFI
No fair! I asked first.
Am I wrong or not?
I couldn't start to help until I understood what he was saying, or how he derived it. It looked to me, that somehow he thought he'd altered his LSA, and that he was saying that he had 16° of overlap. It wasn't until more info was tossed around, that I figured the overlap number was at .050". Although I STILL haven't seen a confirmation that is what happened, I do believe it, until told differently. Sorry, I was so slow to "read between the lines".
RACE ON!!!
Old Dec 23, 2005 | 03:27 PM
byebyeL98's Avatar
byebyeL98
RACE ON!!!
Confirmed - the overlap number of 16* was at .050".
Old Dec 23, 2005 | 04:54 PM
CFI-EFI's Avatar
CFI-EFI
FYI, overlap at .050" is not a spec that is readily known or compared. It's a worthless figure.
RACE ON!!!
