ZF-6 into 85
Old Dec 23, 2005 | 04:51 PM
ZAWA's Avatar
ZAWA
Default ZF-6 into 85
Got all the parts together and it went like butter. Thanks to Central Coaster's page with all the part numbers and when they were used on the different years. I think that is the key to a eazy job of it.
Used the ZR-1 pivot stud and had longer clutch line made out of the old one. Clutch engages like on the 4 speed. The C beam was much easier to put on the ZF-6 then on the 4-3. Now have to get the new carpet in. And finish the LT-1 heads.
Old Dec 23, 2005 | 05:25 PM
bogus's Avatar
bogus
CC did SO much work to get that page so well documented. His labours made the process that much easier for you.
to CC for all his efforts!!!!
LT-1 or LT1? Are you putting an LT1 in your car???
