Removing cat converter bolts???
Old Dec 24, 2005 | 08:38 AM
Fastmax32168's Avatar
Fastmax32168
Default Removing cat converter bolts???
This is a pic of the bracket that holds the cat on my 94 LT1. Are these nuts spot welded from this side or is this a nut/bolt combo? Any suggestions on what it takes to get these loose?
Some may recall I couldnt get my headers to sit flush against the block. It turns out my pipes are located about 1/2" closer together than the header outlets and I need to get the passenger tailpipe moved over toward the frame rail. Even though the bolts were loose holding the header and cat pipe together they are just too far off and they prevent the header from mounting properly. Its either get these bolts loose and twist the pipe outward at the joint or heat it up behind the cat and bend the whole pipe from there.
Suggestions?
Roy
Old Dec 24, 2005 | 08:45 AM
mseven's Avatar
mseven
I do remember your post at least you found the problem.
Only a couple of ways I know, I would first try and soak w/ PB blaster they might come off or snap, or get a torch on them.
Old Dec 24, 2005 | 08:54 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
The "hot wrench" was the only way on mine.
Old Dec 24, 2005 | 09:10 AM
Slalom4me's Avatar
Slalom4me
If the nut still will not budge after soaking with a
penetrant then before resorting to the gas axe, try a
sharp chisel (w/ safety glasses).
Get the end of the chisel square on the edge of the
flats. First knock it in the direction required to tighten
the nut, then drive it in the direction to loosen the nut.
If this is unsuccessful, you can use the chisel to split
the nut with a few blows.
Be sure to take a moment with a file to dress the end
of the chisel for best results.
Fastmax32168
Default So...
Are they a nut/bolt combination or is one side part of the bracket? I can just cut it off with the die grinder if it is just a nut.
Roy
Old Dec 24, 2005 | 09:15 AM
Corvette Kid
Roy
Mine are long since relegated to the scrap pile but if I remember right, the bolts go into a welded nut on the brackets.
Old Dec 24, 2005 | 09:52 AM
Slalom4me's Avatar
Slalom4me
I don't know either. On the nut on the right in your
picture there appears to be a small puddle of
weldment at the top. In any event, removal of the
nut with the die grinder, chisel or torch should release
the rest of the bolt.
Be careful working under the car. There is a thread
in C4 General about incidents where problems
occured due to insufficient support.
Old Dec 24, 2005 | 10:22 AM
Brimis's Avatar
Brimis
Suggestions?
Roy
The nut should be 5/8. I would soak it in WD-40 then get a socket and an extension for leverage.
A power tool will loosen the bolt before you can say jiminy cricket!
Old Dec 24, 2005 | 10:36 AM
Fastmax32168
Default Still stuck
Jimis, Air wrench had 0 effect on it which is why I thought it might be welded. It sure looks like it is in the pic. You can see it better in the pic than in person actually.
Slalom. Pretty sure I have it sufficiently supported.
Old Dec 24, 2005 | 11:56 AM
Brimis's Avatar
Brimis
When I posted eariler, I just rolled out of bed, no coffee, no glasses. I hope I'm not giving my age away!
Looking at the picture, it appears to be spot welded. Perhaps you can sharpen a chisel and carefully chisel it off.
Looking at your arrangement, sharpening a chisel should not be an issue!
Old Dec 24, 2005 | 12:16 PM
mseven's Avatar
mseven
I just posted back as I saw the 4 post.... about the only thing I am missing.....I'm jealous Nice set-up....Don't worry, take your time it will come off, your not going to hurt anything
Old Dec 24, 2005 | 12:47 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
...and least of all yourself with that lift setup...
To Removing cat converter bolts???
