Where is the PCV Valve?
Old Dec 24, 2005 | 03:08 PM
aug1516's Avatar
aug1516
Default Where is the PCV Valve?
I know this may seem like a stupid question but can someone please tell me where the PCV valve is on a 1995 LT1 Corvette? I wanted to replace the valve as part of routine maint. but I have no idea how to find it.
Old Dec 24, 2005 | 03:13 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Under the drivers side fuelrail cover. One side of the U shaped hose goes to it.
Old Dec 25, 2005 | 04:16 PM
aug1516's Avatar
aug1516
Thank you so much.
Old Dec 26, 2005 | 12:47 AM
Jet-Jock's Avatar
Jet-Jock
That hose gets awful brittle, when I replaced mine the hose was hard and it cracked. Special shaped hose too. A new one is soft and supple, I guess the heat gets to it after a while.
Old Feb 17, 2006 | 10:46 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
You have to be careful not to break the surrounding vacuum lines, too.
Old Feb 17, 2006 | 10:59 AM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Where did you find replacement hoses? There is a ribbed u-shaped hose just off to the side and behine the TB on the passnger's side of the intake on my LT1. It is cracked and looks like hell. I have no idea where to get a replacement short of the dealer... and I'm not sure that they would know what I'm talking about!
Old Feb 17, 2006 | 12:39 PM
Jet-Jock's Avatar
Jet-Jock
Call Chris at Superior Chevy. They are most likely discontinued but you'll want the part numbers. From there contact Vintage Parts and give them the part number. 1-877-846-8243
For the vacuum harness assembly that goes from the EGR on the driver's side it is: 10105325
To Where is the PCV Valve?
