Catalytic converters.
Old Dec 26, 2005 | 11:28 AM
jan-erik's Avatar
jan-erik
Default Catalytic converters.
Hi.
I have an 85 z-51 4+3 modified with large tube runners ported plenum, intake, heads and TPIS long tube headers and a very low restriction catback system
The cam ( hydraulic flat tapet) is relatively large 221/230 @ .05 and lobe sep 112 degrees.
I have a Catco converter what is called high performance. I suspect it restricts the engine a bit. I have 300+ hp.
I am thinking of buying a Random Technoøogy cat.
Does anybody know if there is a difference in the flowrate between the Catco and Random Tech.???? Is itworth the cost??
Old Dec 26, 2005 | 12:16 PM
bogus's Avatar
bogus
yes. I would actually get rid of the center cat and get 2 bullet cats and a Borla X-Pipe.
That would rock.
As for cost, the RT bullets are about $150 each, whereas the Carsound cats are a bit cheaper and just as good. Carsound is made by Magnaflow.
Old Dec 26, 2005 | 12:38 PM
MYCoupe's Avatar
MYCoupe
Just make sure that you get a metal matrix cat. They flow much better than the older ceramic ones. I would actually recommend Dynatech cats. They will flow as well as the Random Tech ones for a little less money.
To Catalytic converters.
