Teardown Completed - Large Pics
Dec 26, 2005 | 09:10 PM
I was able to put in another 5.5 hours the last 2 days.
The heads are off, the Cam is out, Oil pan is removed.
The entire teardown took me 12.5 hours over 4 days.
Here are some more pics:
Heads are off:
3 year old spark plugs:
Timing cover is off:
The Cam hits the CrossBar.
The Cam is out after I jacked the motor, the passenger side motor mount bolt had to be removed. Only had to jack it about 1 inch.
The new Cam is going in.
Dec 26, 2005 | 09:16 PM
You're not messin' around eh?
Thanks for sharing with us!
Dec 26, 2005 | 09:27 PM
That's not aluminum on the spark plug
threads, is it?
Tell me it isn't.
Dec 26, 2005 | 09:31 PM
Quote:
threads, is it?
Tell me it isn't.
That is Anti-Seize thread protector.
I use it on anything that goes into Aluminum.
Vic
Dec 26, 2005 | 09:33 PM
Where's the cam lube on the new cam? Looks good.
Dec 26, 2005 | 09:34 PM
St. Jude Donor '05
How many miles are on the shortblock? What cam/heads?
Keep the pics coming!
Dec 26, 2005 | 09:51 PM
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
Quote:
Looks like a roller cam, no need for moly lube, just a coating of engine oil.
Dec 26, 2005 | 09:53 PM
It sure looks like way too much RTV was used on prior intake install? Am I wrong on this?
How many miles on those plugs? Looks like they are burning cleanly, but man are they rusted on the outside!!
these are really awesome pics!!!
Dec 26, 2005 | 10:15 PM
Dec 26, 2005 | 10:30 PM
Dec 26, 2005 | 10:45 PM
Thanks for posting the pics. Looks like the same parts I just pulled out of my 91. It doesn't look like you capped off your fuel line. When I pulled my engine out fuel kept running out of one fuel line so I plugged it. The next day fuel was dripping out of the other fuel line. What did you do to keep fuel from running out of your gas line?
Dec 26, 2005 | 10:50 PM
The motor has 82K Miles. It was never opened up until the last few days by me.
The Lingenfelter 219 Cam just went in.
Vic
Dec 26, 2005 | 10:52 PM
Quote:
All I did was unscrew the gas cap and the fuel stopped coming out.
Vic
Dec 27, 2005 | 12:26 AM
Looks like I'll be visiting this page often. I'm probably going to be taking the heads off an 88 soon so I might start a large parade of questions. I hope the 88 and 89 are exactly the same thing, minus the 9th injector on 89s, eh?
Dec 27, 2005 | 01:42 AM
Ok, thanks, that idea never occurred to me. Live and learn.
Greg
Dec 27, 2005 | 03:57 AM
Are this stock '89 pistons? On my '90 they look different.
They aren't dished like yours.
Dec 27, 2005 | 07:49 AM
What cam are you putting in ?
Are you changing out the heads too?
Dec 27, 2005 | 08:11 AM
Quote:
Ask me anything you need. I have tons more pics also.
88 and 89 are exactly the same, except for the 9th injector, but thats no big deal at all.
Vic
Dec 27, 2005 | 08:12 AM
Yes , stock 89 Pistons. Do you have pics of your Pistons ?
Vic
Dec 27, 2005 | 11:28 AM
I wish I had los cajones grandes to do that to my car. At least they are big enough to do it on another's car, but since I have no other alternative DD like her, I guess I won't be ripping at mine until something breaks, rendering it undriveable. Was your car running perfectly before you started the chop chop??
