afpr leaking
Old Dec 28, 2005 | 08:17 PM
86SC's Avatar
86SC
Default afpr leaking
i just installed an accel adjustable fuel pressure regulator, it's a newer design then in the instructions, it has a thick base and now retaining ring, i tightened it down, i believe if i tighten these bolts anymore they will snap, it leaks fuel out of the screw holes but not around the diaprham on the outside, anyone had this problem? i dont know what i should do about it
Old Dec 28, 2005 | 08:38 PM
John A. Marker's Avatar
John A. Marker
Default Too tight
Sounds like you tightened the screws too tight. That could cut the diaphragm so the fuel is working into the hole for the screw and up around the screw. Think you need a new diaphragm.
