smog pump
Old Dec 29, 2005 | 12:33 AM
rrthomas1963's Avatar
rrthomas1963
Default smog pump
i have a 85 vette i want to remove the smog pump and replace it with a pully. my questions is besides the pumpwhat do i need to pull off and plug off, and will this mess up my emissions? or is this a bad idea? thanks rosco
Old Dec 29, 2005 | 12:41 AM
VetBoy89II's Avatar
VetBoy89II
I'm not sure what state you are in, but in most states, you will never pass the visual portion of the SMOG test. Check into your local SMOG rules first. But then again, you can always revert back to your stock setup just before SMOG check time, tha'ts what I do out here in California with my long tubes ...
If you decide to go ahead and do it (if it's worth your time), let us know because it is a process but it can be done.
Old Dec 29, 2005 | 01:07 AM
rodj's Avatar
rodj
If visual is a problem , gut the vanes out of the inside and leave it in place.
If removing to be replaced by an air pump eliminator , you can remove all or part of the system including the AIR valves and plumbing.
You will need to cap the air inlets to the exh manifolds and the cat air feed.
Certainly makes front of engine access easier.
No codes
Old Dec 31, 2005 | 12:38 AM
rrthomas1963
thanks for the info texasis the state i live in . stay safe rosco
To smog pump
