Reset ECM code
Old Dec 29, 2005 | 12:00 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Reset ECM code
Is the only way to reset the ECM codes, is to disconnect the battery?
Also, where can I findout what CCM code means?
TIA
Old Dec 29, 2005 | 12:02 PM
Fork501's Avatar
Fork501
TIA
I believe there's a fuse you pull out. I can't recall right now which one it is. If you check your fuse panel, it may make sense. Sorry, but I'm at work XD Good luck!
~Derek
Old Dec 29, 2005 | 03:46 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Would it be the battery fuse?
Old Dec 29, 2005 | 03:53 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Chassis Control Module=CCM
http://www.c4guru.com/articles/CCMCodePull.pdf
Old Dec 29, 2005 | 03:56 PM
Morley's Avatar
Morley
Check your battery cable. Do you have a heavy ga wire coming off the positive terminal and going to a fuse holder in the engine comp? If so that is the FP/ECM fuse, pull it for a minute and then reinstall.
Old Dec 29, 2005 | 04:40 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Thanks guys!!
To Reset ECM code
