Headlight motor wiring question
More likely it is a relay. They are mounted in front of the wheel on the driver's side. Or could be the motor itself.
Manually open the headlight to half way then see if it will go up or down from there. Two of the relays are the same. You can swap them and see if the problem changes sides. They control the left and right side UP direction. The other relay controls both sides in the DOWN direction.
Here is a link to a simplified diagram;
http://pg.photos.yahoo.com/ph/black8...f6.jpg&.src=ph
Start there and see what happens. Take notes and post all symptoms you see.
IIRC, there is a "circuit breaker" of sorts inside the motor too, that could be bad. And did you manually turn the motor to see if that would "wake it up"? Just mind the fingers.
»keith
I think my next step will be to remove the motor and give it a good once over. I'd be just as happy to not remove the side that is good-I don't have a very good track record messing with things that aren't yet broken, and one headlight that opens is definitely better than none!
Another test is to remove the plug on the bad motor, and put a test light in the sockets and see if it has power. Your GM manual should say which wires have power for up and for down.
Hopefully we aren't being too redundant, you mentioned something about replacing a wire. I think I glossed over that cause it it a rare problem, typically, and a more difficult one to fix. If it turns out that no power is getting there, and the relay is good, it could be a wire, or, more likely, a bad fusable link(which is basically a wire.
)For wire repairs, I like to solder and shrinkwrap bad parts, it often helps to splice in some wire as the part that breaks is often old and brittle, but typically, unless it has been very overloads, replacing a whole length of wire isn't necessary. Crimps can be OK too, but I think shrink wrap makes connections last much longer by keeping water out.
HTH»keith
1. unplug the motor
2. open the headlight manually
3. plug the motor in (keep hands clear - it should shut)
Sorry for being so slow in posting. I just got busy.
From what you have done so far it sounds like the motor to me. There are two internal limit switches that stop the motor when the assembly is up or down. Go back to the link I posted and hit the "Back to album" button and look at the photos I posted. You will see the inside of the motor and where all the parts are.
»keith
