Vortec head question
Old Dec 30, 2005 | 09:36 AM
MR NICE's Avatar
MR NICE
Default Vortec head question
I have seen advertised Vortec heads drilled for early style intake,will this work or is there more to it?Thanks for any help.
Old Dec 30, 2005 | 10:34 AM
gbody5's Avatar
gbody5
If you plan on using these heads with TPI you need a TPI intake made for Vortec heads, I have seen them from scoggin-dickey <sp> and another vendor, the name escapes me right now, probably the same manufacturer.
Old Dec 30, 2005 | 01:45 PM
MR NICE's Avatar
MR NICE
What about with a regular 4bbl.intake?
Old Dec 30, 2005 | 01:52 PM
CFI-EFI's Avatar
CFI-EFI
IF the "regular 4bbl.intake" was designed for use with the Vortec heads, yes.
RACE ON!!!
Old Dec 30, 2005 | 02:31 PM
86VX1's Avatar
86VX1
a regular 4 bbl intake will bolt to vortech heads if your heads are redrilled for the older style intake pattern.
I would not reccommed you do that because the intake ports of the vortechs a placed higher than the intake ports on older style intakes, you would have a step in the path of airflow, for what it would cost you to modify the heads, about 75 bucks from a local machineshop and gasket port match the intake to the heads, proba bly another 50 bucks,
you could easily get the correct intake designed for vortechs.
Old Dec 30, 2005 | 03:31 PM
gbody5's Avatar
gbody5
Just get an intake made for the Vortec heads.
Old Dec 30, 2005 | 03:40 PM
MR NICE's Avatar
MR NICE
I was thinking of a stealth weiland,or excellarator to clear hood on 85,anyone know of a single plane vortec intake that will fit under an 85?
Old Dec 30, 2005 | 04:58 PM
86VX1's Avatar
86VX1
man, you are in a real pickle, i just checked the summit racing catalog and scoggin dickecy, and found nothing.
have you tried checking the dual plane intake from gm performance parts, especifically designed for vortec heads, to see if you have enough clearance? I think there's a high rise version and a lo rise version made for camaros, I could be mistaken though.
Old Dec 30, 2005 | 09:38 PM
ElisTwoCents's Avatar
ElisTwoCents
St. Jude Donor '05 thru '24
man, you are in a real pickle, i just checked the summit racing catalog and s, and found nothing.
The intake is in their current mag and available through the scoggin dickey website
Old Jan 2, 2006 | 03:02 AM
ZD1's Avatar
ZD1
The GMPP vortec/fastburn have .25" raised ports. You'll need a manifold to match the port. There's a recent post about someone using the LT4 intake (modded for coolant flow and the distributer).
Get to your nearest dealer for the GM performance parts catalog. When I had my fastburns flow tested, the GMPP single plane intake actually added 5 CFM to the flow after port work.
Old Jan 2, 2006 | 06:38 AM
rodj's Avatar
rodj
GMPP # 12366573 Dual plane hi rise
#12496820 Appears to be lower version of above
#12496922 Single plane Eliminator design
Check out http://www.superchevyperformance.com...kes/sbintakes/
12496820.asp
To Vortec head question
