Blinker problem
Old Aug 3, 2001 | 03:37 PM
Cannonball's Avatar
Cannonball
Default Blinker problem
I need to get this fixed soon as it is fairly dangerous. My lights are fine, this is a problem with the steering column stick itself. I push it down and have the blinkers for a left hand turn click and go on, but then you can't push it back up to make them turn off. You actually have to turn the steering wheel to the left enough for them to automatically go back in the middle. It won't even catch for a right hand turn. You push the lever up and it keeps on going and no lights will turn on. I am assuming you have to get into the steering wheel to fix this which I believe is a pain right? Is this something you guys recomend taking in? Thanks,
Eric
Old Aug 3, 2001 | 03:54 PM
JYD69_427's Avatar
JYD69_427
Default Re: Blinker problem (Cannonball)
I own an '87 that had a blinker problem when I bought it. Fortunately, I have had several GM columns apart before...the first one is a real learning experience.
Unless you have a steering wheel puller and lock plate removal tool, forget about doing it yourself. You need to remove both to gain access to the turn signal assy.
I was amazed to discover that it is also possible to reassemble the Corvette's cancelling cam incorrectly and it still goes back together. But then, your signals won't cancel properly (when making things fool-proof, never underestimate the ingenuity of fools :lol: )
Being both cheap and curious, I disassembled the turn signal assy and re-terminated the wires that were loose. Just imagine the scene as I was reassembling the two plastic halves when the spring went sproing! Fortunately, I found it in the back of the car after an extended search.
Old Aug 3, 2001 | 04:26 PM
Cannonball's Avatar
Cannonball
Default Re: Blinker problem (JYD69_427)
Thanks, It's too hot in Arizona right now to be spending that much time in the garage
Old Aug 3, 2001 | 06:00 PM
Ramjet's Avatar
Ramjet
My '92 has been like that for over 3 years, someday I'll get it repaired.
I live in the Chicago area where no one uses turn signals anyway...
Old Aug 3, 2001 | 07:42 PM
No Ordinary 91's Avatar
No Ordinary 91
Cruise-In III Veteran
Might be low on blinker fluid..... :lol:
sorry couldn't help myself since no one else has done it yet :D
To Blinker problem
