85 performance for the money
Welcome to the club
Header's, intake, & a custom chip.
That should make you hungry.....
Get a good feeling for where you want to be, then find a combination already out there that has achieved those goals. Put together a gameplan and persue it matching that combo as close as possible.
This not only saves you lots of money in the long run, but much further ensures success will be achieved.
Only problem is if your like the rest of us, once that goal is achieved you will find yourself hungry for MORE.
Its a sickness so either jump in with both feet, or walk away while you can.
how much money do you have to spend on mods? this will give us a better idea of what parts are going to give the best results.
starting with the exhaust is your best bet.
Set yourself a budget, and than add 2% on top of it for last-second expenses that usually creep up.
If you shop wisely as I have, you could upgrade your car's parts for little or not money .
Just FYI, on my stock Z51, I picked up almost a second off my 1/4mile (with a slightly slipping tranny) by adding : superram intake, SLP ram air system, BPP airpump elim kit, A/C bypass belt, 52mm TBody, cut-back electrode sparkplugs, LPE Longtube 1 5/8" headers, High Flow catalytic converter, Targa Mufflers, and started programming my own custom chips.
I shopped wisely, sold old parts not needed anymore, and spent only about 600 out of pocket..
However.. Ski_down_it is right.. Once I got the low 13's I wanted more, so added heads, ported everything, got me to low 12's, and now I added a supercharger..
And still I've only spent about 2K on everything.. (well.. Plus $2k on a new tranny I needed last year (But that's not really a performance ugrade)..
My 350 setup lost .75sec with a converter change. My 434 this past year gained over .3sec with a change to the existing converter to make it more efficient.
Its unfortunately one of the last things people tend to look at, but should be included with things like intake and head changes.
Just something to think about...Now if you have a manual...forget the entire post..it was just a general speaking comment.
if u want performance, dont buy an 85.
But the follow up by ART, had me in stitches. And all this happened during a post I was putting together.
I have an 85 check out some of the mods I did.
HOOT
Also refer to 85VETTE the guy I bought my power effects from Jim in Pittsburgh. Hes a great guy with an 85 and runs 11"s maybey 10"s now.
I describe it as, you program it to do X it does X. I call it the Forest Gump of ECMs. tell it to run, it runs till you tell it to stop. There are no variations in the code that will apply "gradients" to the request you give it like later model ECMs do.
There are SEVERAL very strong running 85 cars here with times in the deep 10s and 11s.
Also another little tid-bit - 85s came with forged pistons stock.
Not the junk ones the later years came with. I am sure each year had its +s and -s.
Make out a plan with set goals, either in ET or power numbers, and we'll tell you what you need to get there.
Do not spend money on a chip until after you are either done with mods totally, or have changed the cam.
85 already has a 2026rpm TC, so if you have an automatic, dont worry about changing that yet. Start with the exhaust. After you have set your goals, then think about what intake setup you want. My site has some details.
The car had a cam when I bought it, it dynoed 230rwhp, that is what it's rated at the crank from the factory, so about a 15% power increase with the cam alone. (don't know specs)
I added a Miniram and picked up 4hp. The super ram may have yielded better results but I would still say that the intake is not the place to START. Depending on your goal it may be needed in the future but in my experience the heads/exhaust/cam are likely to provide better results, again, to a point.
And Jesse is right about the 85 ecm, maybe not the fastest but I think the most forgiving. I put my 408 in and forgot to unclamp the return fuel line when I started it, it started and ran with 70psi through 36# injectors. Fixed that little glitch and it ran mid 12's at 115 with a stock chip and plugs that were 3/8" too short. (AFR takes a longer plug than stock).
OH..and the money you save with buying an 85 vs say an 88, is worth alot more power in the aftermarket than comes with a newer L98. i.e. Buy set of 180cc AFR and a cam with the 2K you save and go smoke a few 86+'s.
As I said, the converter on both of my setups either made or broke the setup. Its just something I see people overlooking here and wanted to mention it.
i am sure there are.....in fact, there are tons of them running around with different motors then what the car came with from the factory.
What's up with that comment?
