collapsed lifters?
Old Dec 30, 2005 | 04:28 PM
pr0zac's Avatar
pr0zac
Default collapsed lifters?
ok so i have had like two different sets of lifters go bad on two of my engines.. i set them all up the exactly the same. i upgraded cams in both engines and bought new lifters for the new cams... i cleaned them off, soaked them in oil for a few hours and threw them in. well i went to zero lash and did a half a turn from there tightened the locks... well on one engine, half the lifters wouldn't stay pumped up and clattered real bad.. and on the vette two lifters blew out the top and 5 others wouldn't stay pumped up. what am i doing wrong? on another engine i set them up the exact same way and they work perfectly fine and stay pumped up like they should and this engine has the largest cam and strongest valve springs of all the engines???? one set was comp cams stock replacement lifters and i can't remember off hand what the vette had. i bought a set of sealed power for the vette cause it was the only brand readily available locally... i need to put them in but want to be sure i am doing things right first.. any suggestions would be great!!!!! thanks..
btw all are hydraulic roller lifters..
Old Dec 30, 2005 | 04:33 PM
STL94LT1's Avatar
STL94LT1
It sounds like you may not be setting the valve lash properly. You have to be careful on new lifters. Because initially they will be soft, and you may set the valve lash too deep.
Old Dec 30, 2005 | 04:41 PM
pr0zac's Avatar
pr0zac
i am using true roller rockers on these engines.. so i can get to zero lash with my fingers and am only setting the lash at a half turn... i mean even if i were to go past zero lash i have heard of people setting valve lash up to 1 1/4th in from zero lash. i am not using comp "r"'s which i know are really picky and only need like a very very small amount of lash.
Old Dec 30, 2005 | 04:46 PM
CFI-EFI's Avatar
CFI-EFI
Be sure you start the preload from ZERO lash, not the too often mistaken, bottomed out position. Also, don't soak the lifters in oil.
RACE ON!!!
Old Dec 30, 2005 | 04:50 PM
STL94LT1's Avatar
STL94LT1
When I installed my second cam. I had one of the lifters out of adjustment and colapsed a lifter and broke a push rod. When I installed the new lifters. I did the initial valve adjustment. Then spin the engine over with plugs out/intake off, until I had full oil pressure, and then readjusted the lifters just to make sure. After several months they appear to be in proper adjustment.
Good Luck.
-Mike
Old Dec 30, 2005 | 04:52 PM
STL94LT1's Avatar
STL94LT1
Originally Posted by CFI-EFI
:Also, don't soak the lifters in oil.
Why's that?
Old Dec 30, 2005 | 06:24 PM
CFI-EFI's Avatar
CFI-EFI
It is recommended not to soak them by several engine parts manufactures. I forget all the details of exactly why. If memory serves, it seems the non-compressible liquid can stack solid and cause breakage upon initial fire up.
RACE ON!!!
Old Jan 2, 2006 | 05:16 AM
Daniel DK's Avatar
Daniel DK
RACE ON!!!
hmm - when i bought my comp-cams last year, there was a note in the box which said to soak them...
Old Jan 2, 2006 | 08:48 AM
MBDiagMan's Avatar
MBDiagMan
What weight oil are you using and what does your oil pressure look like?
Good luck,
Old Jan 2, 2006 | 09:18 AM
mseven's Avatar
mseven
What method of lash adjustment did you use? What I have found that works for me is the Comp. Cams .030 method. By doing one at a time, spinning the motor by hand, and going right down the bank 1-3-5-7-8-6-4-2 so that I know for sure that each one was set right. By following their method you can be certain that you are on the base circle of the cam when adjusting the lash (starting at that point from zero to then pre-load the lifter). The lash should be alright with + or -.010 (roughly 1/4 turn) without lifter problems. I don't like the GM method, very easy to do wrong valve or forget sequence of what was done or not done. I am not sure why you say that CC pro mags or any roller rocker needs less or is any more 'picky'.
Old Jan 2, 2006 | 02:06 PM
EvanD's Avatar
EvanD
CF Community Team
Going by memory you should use a push rod and push on each lifter to get the air out, comes out the little bleeder hole in the side of the lifter. You keep pushing untill there's no more bubbles. If you don't do this and you install and adjust them, as soon as the oil pressure pumps them up good they are WAY out of proper adjustment, should run like crap too...
Old Jan 2, 2006 | 04:17 PM
JAKE's Avatar
JAKE
There seems to be a little confusion about proper prepping new hydraulic roller lifters before installing them.
I'm aware that a few cam companies - ISKY and CompCams come to mind from memory - specifically recommend NOT to pump up the lifters with oil before installing them in the bores.
On the other hand, they do recommend that the roller bearings in the lifters be cleaned of the grease that is used during the assembly of the lifter at the factory. I recall ISKY stating that failure to do so will prevent proper oiling of the bearings at the roller and can result in roller bearing failure.
So based on all that, I've concluded that the new lifters should be inserted in clean solvent, the roller turned to dissolve and remove the grease, dried and lightly oiled to prevent dry start up BUT the lifter body should not be pumped up.
I had to order a custom set of off-set lifters for a friend's 434 when it was going together and the lifters came with a WARNING sheet in the box saying to remove the factory installed grease. They were ISKY's.
Jake
To collapsed lifters?
