85 scanner
Old Dec 30, 2005 | 07:24 PM
morodder's Avatar
morodder
Default 85 scanner
what is a good scanner or software to use. thanks for all your help
Old Dec 30, 2005 | 09:03 PM
JoBy's Avatar
JoBy
WinALDL works for a 1985 Corvette.
http://winaldl.joby.se
Old Dec 30, 2005 | 11:11 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Without a doubt you will not find a better scanner than EASE. It's VERY stable and very user friendly.
If you need help finding it shoot me an IM and I can locate a dealer for you. My buddy that has the 85 vette, uses it and I borrowed it a few times.
Works real nice and is nice software. Tried lots through the years and its by far the more reliable. Nothing is worse than making a run or trying to capture the data and looking down after and its diconnected and you have to tinker with it for 10minutes trying to make it work again to only get the same results.
Just my thoughts.
Old Jan 2, 2006 | 10:35 PM
85_TPI's Avatar
85_TPI
Sorry about my ignorance but, what is EASE?
I haven't heard of it and would like to know...
thanks,
85_TPI
Old Jan 3, 2006 | 09:17 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
thanks,
85_TPI
Here you go, This should help you out. About 1/2 way down the page you can see where it says software screens. You can go there and pick GModb1 at the bottom and it will give you a slide show of the screens and software..
Let me know if you need any more help!
Old Jan 3, 2006 | 05:31 PM
85_TPI's Avatar
85_TPI
I'm sorry. Was there a link of some sort that may have been left off?
Old Jan 3, 2006 | 10:23 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Opps sorry I must have missing the paste command.
Try this:
http://www.obd2.com/scantool/scantool_gm.htm
should be able to find everything you need from there.
Good luck!
Old Jan 3, 2006 | 11:02 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
My vote is for winaldl also..
Joby, are you the creator? If so coudl I bother you with making a custom definition for me? If so I'll be glad to make a good donation for your efforts?
Old Jan 4, 2006 | 11:26 AM
GRX's Avatar
GRX
FYI - EASE works very 'strange' on my 85. Reports codes that DIACOM (very good) and WinALDL (very good) do not report. I've contacted EASE tech support to no avail. Wasted my $$$ on EASE.
Old Jan 4, 2006 | 11:38 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Never once had a problem on any of the cars I have scanned with it. Perhaps you have a specific problem with your car - hence the reason the tech people can't seem to pinpoint the cause.
I used to leave mine running on my car the entire day at the track, startups/shutdowns, ect - never once did it loose connection.
Other scanners I tried along through the years - continually had connection and other related freezing problems. But perhaps it was my setup - EASE did a nice job though.
Old Jan 4, 2006 | 01:16 PM
GRX's Avatar
GRX
Also, checked my EASE setup on a co-worker's '85 and rendered the same results. Perhaps my EASE is defective. Like I said, Diacom and WinALDL work fine on mine.
Old Jan 4, 2006 | 06:08 PM
85_TPI's Avatar
85_TPI
If I'm not mistaken, Gordon Killebrew recommends the Diacom Plus.
Anyone know the best place to go for this?
thanks,
85_TPI
Old Jan 4, 2006 | 09:59 PM
GRX's Avatar
GRX
thanks,
85_TPI
I got mine years ago from either Midamerica or Ecklers. In either case check with Rinda Technologies for their distributor list. ...or save yourself some cash and get JoBy's WinALDL. I have it..works good. The cable is easy to make too.
Old Feb 9, 2006 | 08:53 PM
cliffsurfs's Avatar
cliffsurfs
Cruising
Default scanner
I have a like new OTC monitor 2000 scanner that will not work on my 91 tpi, but would be great for your 85. It will scan 81-89 GM, Ford, Chrys. With my 91 all I get is no data do to baud rate. It looks new some of the orig. connectors are still bubble wraped. will sell cheap If interested. Playday@sbcglobal.net cliffsurfs
Old Feb 18, 2006 | 01:27 AM
cliffsurfs's Avatar
cliffsurfs
Cruising
Default garth scanner $
garth, if you are out there I tried to email you twice some kinda error will not let me send. the price is $ 130+ normal shipping? back in the 80's OTC monitor 2000 was the hot ticket, had one in my tune-up shop. gives all kinda data, but not on 91 TPI. this unit really looks like new, case and contents. my # is (760)723-8185 cliffsurfs
To 85 scanner
