Coolant fan question
Old Dec 31, 2005 | 07:04 PM
1990 c4's Avatar
1990 c4
Cruise-In VII Veteran
Default Coolant fan question
Washed the vette today, '90 convertible. Now the coolant fans are running any time engine is running. They don't run with key in run position unless engine is running. Would getting something wet cause this? I did not wash engine, just exterior.
Thanks,
David
Old Dec 31, 2005 | 07:20 PM
jfb's Avatar
jfb
I don't see any relationship there. Check to make sure you didn't bump the a/c to the on position which turns the fans on.
Old Dec 31, 2005 | 07:51 PM
1990 c4's Avatar
1990 c4
Thanks! Now I'm going and change my username to "DUMMY".
Thanks,
David
Old Dec 31, 2005 | 09:45 PM
jfb's Avatar
jfb
You aren't a dummy.....a student maybe, and you just learned a new fact.
Old Dec 31, 2005 | 11:47 PM
lyruegas's Avatar
lyruegas
3rd Gear
I've got a different question about the fans. Do they both come on at the same time or are the sequential? I have only seen the driver's side fan come on when it gets hot. It cools everything down pretty quick by itself. Mine is also a 90 L98 convertible with an auto trans...
Old Jan 1, 2006 | 12:19 AM
kize's Avatar
kize
On my 86 with factory second fan runs sequential. Second fan comes on with A/C on or when temp reaches approx 225.
To Coolant fan question
