Need help with this one.....89A4
So if the fanswitch on the drivers side head is kicking the aux fan on at 162, when/what governs the main fan and when is that supposed to come on?
1.) 89 Drivers side-Fan switch for main fan
2.) Pass side-To gauge?
3.) Manifold-To ECM? ECM kicks aux fan on at 228
4.) Someone correct me if I'm wrong..
Man that car is ALL screwed up.
1.) Fan switch for the AXILLARY fan.
2.) Yes.
3.) Yes, BUT, the ECM is supposed to control the MAIN fan.
4.) Done.
RACE ON!!!
..Now I gotta get out there and play with this thing..
RACE ON!!!
The passenger side head sender, is ONLY or the dash gauge. It has NOTHING to do with either fan.
It has been clearly stated, "what controls what".
RACE ON!!!
As far as what has "clearly" been stated. I've read typos in books b4, so nothing to me is clear unless I am actually doing the work and can see it with my own 3 little eyeballs.
Gotta do a quickie edit.
His main fan was coming on early, he replaced his passenger side switch, fan isn't coming on early now. Why do you suppose that is if this has been explained clearly as to what switch does what?
1)Disconnected the connector to the switch on pass side head, no coolant reading, so I guess that's where the gauge gets the reading from
2) Tested O2, works fine.
3)Car runs strong, still has a slight stumble at idle. Sprayed water around runners/plenum/air coupler, nothing,.I'll spend more time around the FI and make sure orings arent sucking air.
4)I'll stick it back on the dyno next week to see where the A/F is at.
Thanks for the help guys, keep you posted.
I'm doing something wrong checking the TPS voltage, cant get a reading. Have the multimeter at 20 (V), black prong in second wire, red in top wire, no reading???
Timing at 6 deg.
Edit: Also stuck that thermomaster chip I've had laying around so main fan comes on earlier now. Good enough.
Timing at 6 deg.
Now I'm curious why that main fan turned off replacing the passenger head switch.
Do you have the TPS harness tester. You unplug your pigtail to your tps and plug this unit in between. There are 2 alligator clips on wires that you hook your multimeter into? It makes checking TPS voltage a lot easier as getting your probes jammed in the pigtail is kinda a bitch.
RACE ON!!!
*I* have explained clearly where each device is and it's function. Goodness knows if he wrote, or you read, correctly about the fan coming on early when he replace the gauge sender. For it's effect on the fan, he may as well have added a quart of oil.
RACE ON!!!
Just because you say it's so means it's so? All I told him to do was pull the wire to test if that's the case. I read what you said and since you aren't infallible I told him a simple test to prove what you said to be right. I stated I didn't remember for sure which sensor did what. Is that a problem? Did you read any other misinformation in this thread? Are you infallible?
Quote the rest of what I wrote before you spout off like you are a supreme deity.
RACE ON!!!
OK. Here is the whole post:Quoting the whole post doesn't make the first paragraph any more correct. You say, "I get it.". But what you post, proves you DON'T get it. Instead, you contract what I say, making it look like you know better or different than I have stated. Say that I am wrong, and then back it up. Some people look to these threads to learn, if you can't contribute in a positive manner, then...
RACE ON!!!
I am not totally sure what switch (front of manifold or passenger head) controls the dash gauge and which sends its signal to the ecm. What I would do if I were you just to find out is disconnect the switch in the passenger head and see if your dash gauge works.
I wasn't trying to hurt your feelings by telling him to pull a wire to verify that the particular sensor in his passenger head was indeed for the temp gauge. I said I don't remember which sensor does what so a test for me to do to verify is pulling the wire. If you notice we posted at the same time this morning when I first said I DON'T REMEMBER. If I don't remember I won't necessarily blindly follow someones facts.
I wasn't trying to one up you, I was giving him something to try to verify what is being told to him to be correct. Is that a problem or should no one on this forum ever question what you say?
You say people come here to learn, guess what? They learned that they can pull the wire on the passenger side temp sensor and see that their temp gauge on their dash no longer works.
Now since he has stated that he pulled the wire and his gauge died I feel VERY comfortable saying that you are indeed correct. THE PASSENGER SENSOR WORKS THE GAUGE AND THE MANIFOLD SENSOR FEEDS THE ECM.
YOU WERE RIGHT AND I STILL DIDN'T REMEMBER THIS MORNING WHAT DID WHAT.
Can we be friends again, I miss ya buddy.
I have NO clue as to why Morley would cite his Camaro or Firebird as examples for Corvette wiring.
RACE ON!!!
RACE ON!!!
RACE ON!!!
Quit looking Cuisin.
